Brrrr
place holder
6 members (Gdads51, Otto Skorzeny, fonz8261, J Lucas, UtahYork, Wally / Montana), 300 guests, and 3 robots.
Topics128,272
Posts1,058,420
Members48,485
#164373 05/19/2006 12:57 AM
Junior Member
Junior Member
I have a 1952 chevy 1/2 ton that is getting a pair of from a 2004 chevy tahoe. These seats are power with memory and heat. Does anybody have a wire diagram to hook it up? These seats have a switch on the door for memory set, 1, 2, and heat control. The connector on the seat has 2 rows of pins, 8 pins on each row. pin A=orange, B=pink, C=pink, D=brown/white, E=black/white, F=green, G=lt blue, H=blue, J=yellow, K=blue, ?=lt blue, ?=white, R=black/white, S=black. The black and orange wires are bigger than the others so my guess is these are the constant power supply. The others must be for the door switch. I would get a helm manual but for that new of a suv they want several hundred $$$$$$. Thank you for any help you could give me.
Check your local library for a manual. If they have one they'll let you copy the pages you need for a fee.
X
X Offline
This may not be that easy to do. I don't know the specifics of any particular vehicle, but I believe the switching is integrated with the vehicle's computer system. Switches nowadays aren't necessarily directly connected to the devices they control. The switches and devices are connected to computer modules, in this case probably at least a driver's door module and the body control module, which communicate via serial signals through the vehicle's communcation bus. The memory function would be part of the body module.
I have the manuals for the 2005 GM pickups that I could look at to verify this. However, I'm away from home and won't have access to them for a while.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
see if this helps.
http://alldatapro.com/alldata/PRO~V18527055~C38642~R0~OD~N/0/101825161/104091466/104091631/104091635/34853741/34869956/34869958/56473457/108046041
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
Never mind, It doesn't work for everyone only subscribers. darn!
#164378 05/20/2006 12:10 AM
Junior Member
Junior Member
wilbur, thats a nice looking truck. what kind of gas tank did you use?
#164379 05/20/2006 12:57 AM
The tank is from a 70 mustang, I made all the frame work.
wilbur
Junior Member
Junior Member
wilbur, i guess you had the same idea. i did the 70 mustang tank in my truck. whats the thing on top of your tank and what other mods did you do?
#164381 05/20/2006 12:20 PM
You must be referring to the sending unit for my classic instrument gauges.
The tank has been modified for efi.
Moderated by  ndkid275, Phak1
