| | | Forums66 Topics128,118 Posts1,056,305 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 19 Junior Member | | Junior Member Joined: Mar 2006 Posts: 19 | What is the interior color on my 64 called? it is a tan or champagne looking color. i would like to repaint the interior with rattle can paint, i think i can do a good job if i prep the metal correctly. are there some vendors who supply this color in rattle cans? thanks for any help you can provide. -anthony
"Send lawyers, guns, and money." W.Zevon
| | | | | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Hi Anthony, The original interior color is called "fawn", there is 2 different shades of fawn. The first color of fawn is for the '60-'62, and the'63-'66 trucks fanw is a another shade. One is a little lighter than the other, I can't remember which one is lighter or darker. :o
I do know a guy off of another board I visit, and he had bought the rattle can fawn color, and he redid the firewall on his '66, and it looks awesome!! He's over on Chevy Talk forum in the '60-'66 trucks page, he goes by the handle "Hilandr451".
There's another guy their too that redid the whole interior the same color on his '65, I believe his handle is "Chevrolet65". I hope this helps. David
My truck don't leak oil, it just marks its teritory.
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | | | | | | Joined: Mar 2006 Posts: 19 Junior Member | | Junior Member Joined: Mar 2006 Posts: 19 | thanks Dave and Brian. I have not had a chance to start work on the interior. Had to have the heads redone so I'm working on the engine compartment now. I guess I'm going to get it running correctly first then start on the interior. thanks again to both of you, -anthony
| | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | As far as getting the paint into an rattle can- If it doesn't require activator/harnder NAPA or your local paint store can put it into a pressurized can for a few bucks. When you mix paint with those ingrediates it begins to degrade immediately and isn't usable after a short while. If it does require that stuff, you can buy either a "perval spray system" refillable aerosol can.
Both are available at Harbor Freight and other vendors.
The Perval system uses disposible cans of comressed air that screw onto a jar that you put the paint into. The tops of the disposible cans have regular rattle can tips and that connect to the jar via a tube from the jar that plugs into a gasket at the bottom of the disposible can.
The refillable areosol can has a screw off lid and an air fitting so you can put the mixed paint into the can, pump it full of air with any pump=hand pump, compressor, gas station's compressor..., and then paint with it. The refillable aerosol can comes with extra tips.
Both work fine.
