1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | When I bought my '41 3/4 ton there were just a few items missing. At the lower center of the dash were 4 round holes made for mounting things. One had a fork truck ignition switch (now replaced). The next a broken choke knob. The third was empty but fairly easily determined to be for the throttle cable/knob. It is the last that has me stumped. The only reference in the owner's manual says auxiliary switch. All the photos on all of the sites that I have looked through do not show enough to ID it. Does anyone know what belongs in that last hole?? | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I'm not sure about others but that's where my heater switch is. It fits through the dash unlike some that clamp beblow the dash. Hope this helps. George | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Kip,
I'm going to make an assumption that your 41 and my 46 would be awful close, if not the exact same. There is at least one picture (pg. 2 I think) of the interior of my 46 in the link below my signature.
Mine are as follows (left to right):
Ignition switch, throttle, choke, cigar lighter.
Hope that helps. | | | | | Joined: Jan 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 63 | Hey Kip,... Yep, Jed's right on. Ignition, Throttle, Choke, Lighter. As in the case of mine and most others, the lighter was an option in those days and a chrome push-in cap was installed.
1941 AK named "PETEY" my buddy.
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Thanks for all the help. No lighters needed here, maybe a dome light or heater switch. (when I get that far) | | | | | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | My '40 has a lighted, rotary heater blower switch in the far right position. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Nice looking truck, I'll need to get a heater before thinking about a "lighted swithh" | | |
