| | | Forums66 Topics128,012 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | I recently bought new door panels for my '54, (of couse they haven't been installed yet). They are basically cardboard and seem susceptible to the elements-grease, water, etc. Has anyone coated these with oil, or some kind of clear coat? | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | tlorber-
I've got mine here & sitting waiting too. They look pretty fragil.
We're going to get ours covered in either black leather or vinyl to protect them. Otherwise, I don't think they could last as long as I expect the truck to.
Sabrina | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Sabrina, Had mine covered in vinyl matching the seats then stitched with a mild flame pattern (all one color) look good to me. the problem I am having is breaking off the plastic fastiners when installing. | | | | | Joined: May 2005 Posts: 147 Shop Shark | | Shop Shark Joined: May 2005 Posts: 147 | All.
Could you use them as patterns, and make some out of 1/4in oak or birch underlayment for tile floors.
Then cover them with vinyl.
-Randy ** | | | | | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | Rti - i did what you suggested on mine but i used 1/8 in. oak plywood. i built a small wooden frame to mount it on and just used some longer screws to mount them to the door. those cardboard ones are really flimsy and i think you are right - if you are going to use them they need a little backing of some sort. now if i would just finish the rest of the interior! i think i have pics of mine (door panel)at http://community.webshots.com/user/djed50
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
| | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | My first set was unvarnished cardboard. Lasted until the first hot, humid, day then started peeling under the window crank. A short time later my knee rubbed through the color. When I finally replaced them, the replacements were clear coated and I've had no trouble for over a year. | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Thanks, all for the input. I think I'll go the clear coat route-not just because I'm lazy but due to the time involved. By the way there is a nice, elaborate description on the Old GMC Truck site by a guy that made door panels out of ABS plastic and then covered them with vinyl. At $9.00 for the pair, I can afford to replace mind if they get tattered. | | | | | Joined: Jul 2004 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 85 | I used 1/8 pvc covered with closed cell foam, then you could cover with just about anything you wanted. No need to worry about water that will get in the door. | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | There is an excellent thread on this very topic over on OldGMCTrucks . Search for "Building a better door panel" Good read.  | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Tlorber, I have fabric covered door panels on one of my trucks. Don't like them near as well as the panels on the other truck. http://groups.msn.com/JedsToyBox/shoebox.msnw?action=ShowPhoto&PhotoID=33 The panels in the picture are very simply and cheaply made. It's a piece of formica that was cut to size and put in place with the bottom facing out. They're tougher than nails, and they match the interior color perfectly, and unless I tell someone what they are, they would never guess. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Go to someone who does automotive work He will have the proper material. You can get the backer in various thicknesses, put light foam over it and stitch or glue the vinyl/fabric over it. | | |
