1 members (ShopRag), 170 guests, and 3 robots.
Topics128,271
Posts1,058,314
Members48,485
#164033 02/20/2006 9:20 PM
I recently bought new door panels for my '54, (of couse they haven't been installed yet). They are basically cardboard and seem susceptible to the elements-grease, water, etc. Has anyone coated these with oil, or some kind of clear coat?
#164034 02/21/2006 5:37 AM
tlorber-
I've got mine here & sitting waiting too. They look pretty fragil.
We're going to get ours covered in either black leather or vinyl to protect them. Otherwise, I don't think they could last as long as I expect the truck to.
Sabrina
Sabrina
'54 3100
#164035 02/21/2006 5:38 PM
Sabrina, Had mine covered in vinyl matching the seats then stitched with a mild flame pattern (all one color) look good to me. the problem I am having is breaking off the plastic fastiners when installing.
#164036 02/21/2006 5:56 PM
RT1 Offline
All.
Could you use them as patterns, and make some out of 1/4in oak or birch underlayment for tile floors.
Then cover them with vinyl.
-Randy
#164037 02/21/2006 7:03 PM
Rti - i did what you suggested on mine but i used 1/8 in. oak plywood. i built a small wooden frame to mount it on and just used some longer screws to mount them to the door. those cardboard ones are really flimsy and i think you are right - if you are going to use them they need a little backing of some sort. now if i would just finish the rest of the interior! i think i have pics of mine (door panel)at http://community.webshots.com/user/djed50
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#164038 02/21/2006 7:08 PM
My first set was unvarnished cardboard. Lasted until the first hot, humid, day then started peeling under the window crank. A short time later my knee rubbed through the color. When I finally replaced them, the replacements were clear coated and I've had no trouble for over a year.
#164039 02/21/2006 9:08 PM
Thanks, all for the input. I think I'll go the clear coat route-not just because I'm lazy but due to the time involved. By the way there is a nice, elaborate description on the Old GMC Truck site by a guy that made door panels out of ABS plastic and then covered them with vinyl. At $9.00 for the pair, I can afford to replace mind if they get tattered.
#164040 02/24/2006 5:05 AM
I used 1/8 pvc covered with closed cell foam,
then you could cover with just about anything you wanted. No need to worry about water that will get in the door.
#164041 02/24/2006 5:10 AM
There is an excellent thread on this very topic over on OldGMCTrucks . Search for "Building a better door panel" Good read. smile
#164042 02/24/2006 5:27 PM
Jed Offline
Tlorber,
I have fabric covered door panels on one of my trucks. Don't like them near as well as the panels on the other truck.
http://groups.msn.com/JedsToyBox/shoebox.msnw?action=ShowPhoto&PhotoID=33
The panels in the picture are very simply and cheaply made. It's a piece of formica that was cut to size and put in place with the bottom facing out.
They're tougher than nails, and they match the interior color perfectly, and unless I tell someone what they are, they would never guess.
#164043 02/24/2006 8:16 PM
Go to someone who does automotive work He will have the proper material. You can get the backer in various thicknesses, put light foam over it and stitch or glue the vinyl/fabric over it.
Moderated by  ndkid275, Phak1
