| | | Forums66 Topics128,022 Posts1,055,360 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 313 | I have tried to locate a used head for my 36 GMC,due to a small crack by #4 sparkplug hole. It is an external leak and I am going to see about getting it welded. The engine is a 213 Olds flathead six. Could I use the 229 cu in head from 37? The bore is 1/8" larger for the 229 engine. I don't think that detonation would be a problem since the comp ratio is around 6 to 1. | | | | | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Two questions . Where have you looked for a head and what is the casting number..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
| | | | | Joined: Mar 2003 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 313 | Have been in contact with French Lake, they have a 229 head from a 1937 Olds, my casting number is 407019. | | |
