5 members (Wheelie, Gdads51, klhansen, greenie-reddy, 1 invisible), 87 guests, and 3 robots.
Topics128,036
Posts1,055,452
Members48,422
#164 09/07/2003 6:52 PM
I have tried to locate a used head for my 36 GMC,due to a small crack by #4 sparkplug hole. It is an external leak and I am going to see about getting it welded. The engine is a 213 Olds flathead six. Could I use the 229 cu in head from 37? The bore is 1/8" larger for the 229 engine. I don't think that detonation would be a problem since the comp ratio is around 6 to 1.
1936 GMC T-14 1/2-Ton Pickup
#165 09/07/2003 10:23 PM
Two questions . Where have you looked for a head and what is the casting number..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#166 09/08/2003 1:28 AM
Have been in contact with French Lake, they have a 229 head from a 1937 Olds, my casting number is 407019.
