0 members (), 171 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#163723 12/02/2005 1:33 AM
I'm restoring a 51 1/2 ton 5-window that is pretty much in original condition. However, need info on I.D. of interior cab color. Bench and side door panels are brown. Existing paint is sort of a bronze, or "champagne" color. Do you know name of this paint and where I can buy it? Thanks.
#163724 12/02/2005 7:34 AM
I'm not certain, but I think Chevs of the 40's has the paint you want. I ordered a quart of interior paint for my 53 from them, but it is possible the 51 would be different. I'm not sure.
I didn't use the paint I ordered. I think it was probably the proper color, but I didn't like it and went with a color combination of my own. I wasn't going for a 100 percent correct restoration, so I said what the heck, when people were still using the truck on a daily basis no one paid any attention to what color they used, the just put what they liked on, so why not do the same now. Allen
#163725 12/02/2005 1:26 PM
Kenz,
I am restoring a '51 1/2 ton too. According to Bob Adler here are the colors and codes: 1947-52 Interior is called Interior Slate Grey but it looks brown metallic, code is (ppg library)DDL3613 or DCC5558. Also DuP C8306. Add flattener.
The steering wheel, column, and gearshift remote control are DuPont DuP 8540.
I hop this helps.
Mark
1951 Chevy 3100
Some days you get the bear. Some days the bear gets you.
#163726 12/03/2005 1:56 PM
51Bolt and Bakerallen:
Geezzzz, you guys are great. Thanks for the input. I'm sure there will be more questions as I proceed. Weather here in Jersey is getting pretty cold and windy so I guess I'll have to crank up the old space heater for the garage. We havin' fun yet??? You Bet!!
#163727 12/06/2005 12:19 AM
on a 53 chevy panel is the color the same as the trucks i have one that is grey orginal and one that is the champange color thanks tom
I don't suffer from insanity, I enjoy every minute of it!
#163728 12/06/2005 2:14 AM
And be aware of carbon monoxide buid up out there in the garage.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#163729 12/06/2005 3:00 AM
Q: This has to do with replacement or coverup of rusted interior cowl kick panels. Catalogs give me two options: a)Replace with metal, or b)cover up with cardboard panels. Some questions:
1. If I replace with metal, can I get away with putting them over existing rusted panels or do I have to cut out old ones? Also, catalog pictures show them as being fairly flat with no real contour. Do they have to be shaped, especially where they meet up with the floor?
2. How do you install the cardboard ones? The catalog postings say nothing about an "installation kit," so do you just glue or screw them in right over the existing rusted panels?
I can't believe how much I don't know.....and I'm just getting started. UUggg!
#163730 12/06/2005 3:03 AM
#163731 12/07/2005 3:06 AM
I'd cut out the bad metal. Rust only spreads.
1954 GMC De Luxe COE
Moderated by  ndkid275, Phak1
