| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 48 Member | | Member Joined: Dec 2005 Posts: 48 | I'm restoring a 51 1/2 ton 5-window that is pretty much in original condition. However, need info on I.D. of interior cab color. Bench and side door panels are brown. Existing paint is sort of a bronze, or "champagne" color. Do you know name of this paint and where I can buy it? Thanks. | | | | | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | I'm not certain, but I think Chevs of the 40's has the paint you want. I ordered a quart of interior paint for my 53 from them, but it is possible the 51 would be different. I'm not sure.
I didn't use the paint I ordered. I think it was probably the proper color, but I didn't like it and went with a color combination of my own. I wasn't going for a 100 percent correct restoration, so I said what the heck, when people were still using the truck on a daily basis no one paid any attention to what color they used, the just put what they liked on, so why not do the same now. Allen | | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | Kenz, I am restoring a '51 1/2 ton too. According to Bob Adler here are the colors and codes: 1947-52 Interior is called Interior Slate Grey but it looks brown metallic, code is (ppg library)DDL3613 or DCC5558. Also DuP C8306. Add flattener.
The steering wheel, column, and gearshift remote control are DuPont DuP 8540.
I hop this helps.
Mark
1951 Chevy 3100 Some days you get the bear. Some days the bear gets you.
| | | | | Joined: Dec 2005 Posts: 48 Member | | Member Joined: Dec 2005 Posts: 48 | 51Bolt and Bakerallen:
Geezzzz, you guys are great. Thanks for the input. I'm sure there will be more questions as I proceed. Weather here in Jersey is getting pretty cold and windy so I guess I'll have to crank up the old space heater for the garage. We havin' fun yet??? You Bet!! | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | on a 53 chevy panel is the color the same as the trucks i have one that is grey orginal and one that is the champange color thanks tom
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | And be aware of carbon monoxide buid up out there in the garage.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Dec 2005 Posts: 48 Member | | Member Joined: Dec 2005 Posts: 48 | Q: This has to do with replacement or coverup of rusted interior cowl kick panels. Catalogs give me two options: a)Replace with metal, or b)cover up with cardboard panels. Some questions: 1. If I replace with metal, can I get away with putting them over existing rusted panels or do I have to cut out old ones? Also, catalog pictures show them as being fairly flat with no real contour. Do they have to be shaped, especially where they meet up with the floor? 2. How do you install the cardboard ones? The catalog postings say nothing about an "installation kit," so do you just glue or screw them in right over the existing rusted panels?
I can't believe how much I don't know.....and I'm just getting started. UUggg! | | | | | Joined: Dec 2005 Posts: 48 Member | | Member Joined: Dec 2005 Posts: 48 | Q: This has to do with replacement or coverup of rusted interior cowl kick panels. Catalogs give me two options: a)Replace with metal, or b)cover up with cardboard panels. Some questions: 1. If I replace with metal, can I get away with putting them over existing rusted panels or do I have to cut out old ones? Also, catalog pictures show them as being fairly flat with no real contour. Do they have to be shaped, especially where they meet up with the floor? 2. How do you install the cardboard ones? The catalog postings say nothing about an "installation kit," so do you just glue or screw them in right over the existing rusted panels?
I can't believe how much I don't know.....and I'm just getting started. UUggg! | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I'd cut out the bad metal. Rust only spreads. | | |
