4 members (Slick Willy, Otto Skorzeny, 1955 1 Series, Rexville48), 66 guests, and 2 robots.
Topics128,024
Posts1,055,390
Members48,422
#163472 08/28/2005 4:24 PM
The teeth on one of my door handle relays and on one of my door window regulators are stripped badly (each on a different door). (The '54 3100 is the truck in question here.)
The mechanisms themselves work fine, but I can't get a handle on either one. My question is, can I have them machined (or something?) to bring the teeth back or am I likely to lose too much shaft diameter for my handles to work any more?
I looked at replacements for both, but 1) I don't really want to spend the money when the regulators still work, and 2) it just too hard to work in the door (we converted one door from a turn-down handle to a pushbutton and nearly ended up in family court!!).
Any advice would be appreciated.
~ Kimberly
My '54 ... and my '63 and a '59 F100
#163473 08/28/2005 5:03 PM
Hi Kimberly, I have a 54 also..I read somewhere, that you can mark and drill a hole in the shaft, so your set screw will fit into it..Will save what ever spline you have left, and make the handle solid..I believe I'm gonna have to do to my window handles...Just a thought, Steve
#163474 08/28/2005 5:52 PM
Thanks Shoop!
~ Kimberly
#163475 08/29/2005 3:45 AM
It seems to me that the question now is, which piece should carry the threads. I would go for threading the hole in the door handle and maybe drilling a small dent in the shaft. If the first try doesn't work out, you can just work on another door handle.
1951 1 Ton Completed
#163476 08/29/2005 12:52 PM
It's like you were in my driveway over the weekend watching me deal with the very same problem Kim! All of a sudden, it came loose and no matter how tight I try to make the screw on the window handle it still turns freely.
I think Shoops suggestion makes sense!
Larry Bear
55.5 Chevy 3100 Panel
Moderated by  ndkid275, Phak1
