1 members (dt235sd), 101 guests, and 5 robots.
Topics128,266
Posts1,058,385
Members48,485
#163356 07/29/2005 10:49 PM
Insomniac
Insomniac
So, what are these 4 slots on the hinge side of the door for? The weather strip is supposed to be glued on... [img]http://members.shaw.ca/ghillsden/misc/doorhingeside.jpg[/img]
Gord 🇨🇦
1954 1/2 ton 235 4 speed
#163357 07/29/2005 11:36 PM
See what you made me do? I went outside and looked at mine, and don't have those things..I would just glue in the new stuff..Maybe you could open a Molson with those..Good Luck, Steve
#163358 07/30/2005 7:31 AM
I have a '51 and I don't remember seeing anything like that before. Are you sure these are stock? Cecil........
#163359 07/30/2005 3:54 PM
Insomniac
Insomniac
Gee, I could open 8 beers at once! (4 on each door). I think that they are on the wrong side of the door - should be on the latch side for a bottle opener.
I am pretty sure that they are stock. Maybe GM had problems with glue in cold weather, so Canadian trucks had some gadgets to help keep the weatherstrip in place?
Once the doors are on, I won't see them.
Gord 🇨🇦
#163360 08/01/2005 6:04 PM
HEY, 22 YRS OF BUILDING THESE TRUCKS I HAVE NEVER SEEN ANYTHING LIKE THAT....
FRAMEUP TRUCKS
FRAMEUP TRUCKS - 47/55.1ST
STILL PLAYING WITH TRUCKS
#163361 08/03/2005 7:35 PM
I have those on my 52. Must be a Canadian thing. There is a clip that slips thru the slot and has one wide end that pushes up against the weatherstrip to keep it in place. I have them in a bag somewhere. I'll try to find them and post a pic. There was not one clutch head screw anywhere on mine either. Everything was phillips head in Canada. Do you have any clutch head screws on yours?
Curt B.
You Tube
#163362 08/03/2005 9:00 PM
Weatherstrip clips makes sense; glue technology is better now, so I probably don't need them.
The only clutch head screws I have found on the truck are on the vacuum motor for the wipers. As you say, everything else is Phillips. I replaced that wiper motor with an electric one, so it is now "clutch head screw free".
Gord
Moderated by  ndkid275, Phak1
