4 members (Bills Auto Works, moparguy, Southerntruck, Napco Man), 118 guests, and 2 robots.
Topics128,049
Posts1,055,680
#163344 07/29/2005 6:09 PM
I just bought a rust free naked '54 cab. There is a hole on the left side of the dash several inches above the headlight switch. It appears "not factory" to me, but I just saw a '54 on E-bay and it has a switch/knob in the same place. Is this a coincidence or was there a factory item that was available for that spot? My original cab, which is a 55/1st has no hole in that area.
Stuart.
#163345 07/29/2005 10:41 PM
Insomniac
Insomniac
Do you mean the hole for the wiper control?
Gord 🇨🇦
1954 1/2 ton 235 4 speed
#163346 07/30/2005 3:06 AM
Gord,
This hole is directly above the headlight
switch, up about two inches. I guess the point is moot now because I just patched and welded the hole shut!!
Stuart.
#163347 07/30/2005 4:40 AM
Insomniac
Insomniac
There's no moss on you! grin
Gord 🇨🇦
#163348 07/30/2005 5:35 AM
Gord,
Between wife chores, firewood, kids motorcycle and work I get about 1 hour a week to work on this thing....strike while the iron is hot!!
Stuart
#163349 07/30/2005 7:57 PM
My 54 had a hole in the same place. No idea what it was for but it came in useful for a tach install bolt.
Christian
#163350 08/07/2005 3:05 AM
This might be the location for the starter button on a Hydra-Matic equipped truck. Is your accelerator pedal pivot on the transmission cover (Hydra-Matic cab) or on the firewall/floor (manual transmission cab)?
Tim
#163351 08/07/2005 3:30 AM
Tim, It's gonna kill you if you find out someone stumbled on a Hydra Matic cab and started welding up the holes after you have been searching for so long to find one isn't it? On the trans cover Tim mentioned, does the front of it seem to "climb the firewall"? or does the front of it end where the floor pans meet the point where firewall starts up? The HydraMatic starter switch would have been about a half inch hole with a skeleto key looking notch at the top and as you mentioned, directly above the headlight switch.
#163352 08/09/2005 4:08 AM
Tim & Greg....let the killing start! That is exactly what this cab was. I knew it was a automatic tranny cab soon after I bought it. I have already welded up the dash hole, and sad to report, transplanted the missing firewall section from my cab to the new one. I had to graft the piece that holds the clutch pedal felt gasket and gas pedal pivot..just like you said. I wasn't aware the Hydramatic cabs were rare.
Stuart.
#163353 08/10/2005 12:17 AM
If you didn't use the HydraMatic transmission cover, There is a round hole in the floor kinda like the one over master cylinder except larger diameter to be able to check trans fluid. If the hole cover is in danger of getting tossed, let me know and I will try and talk you out of it. Thanks, G.H.
#163354 08/10/2005 1:43 AM
Greg,
If I had it, it would be yours.....the tranny cover was missing when I purchased the cab.
Stuart.
#163355 08/10/2005 1:52 AM
I appreciate the thought. Thanks anyway.
Moderated by  ndkid275, Phak1
