| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I just bought a rust free naked '54 cab. There is a hole on the left side of the dash several inches above the headlight switch. It appears "not factory" to me, but I just saw a '54 on E-bay and it has a switch/knob in the same place. Is this a coincidence or was there a factory item that was available for that spot? My original cab, which is a 55/1st has no hole in that area.
Stuart. | | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | Do you mean the hole for the wiper control?
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Gord, This hole is directly above the headlight switch, up about two inches. I guess the point is moot now because I just patched and welded the hole shut!!
Stuart. | | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | There's no moss on you!
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Gord, Between wife chores, firewood, kids motorcycle and work I get about 1 hour a week to work on this thing....strike while the iron is hot!!
Stuart | | | | | Joined: Apr 2005 Posts: 151 Member | | Member Joined: Apr 2005 Posts: 151 | My 54 had a hole in the same place. No idea what it was for but it came in useful for a tach install bolt.
Christian | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | This might be the location for the starter button on a Hydra-Matic equipped truck. Is your accelerator pedal pivot on the transmission cover (Hydra-Matic cab) or on the firewall/floor (manual transmission cab)?
Tim | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | Tim, It's gonna kill you if you find out someone stumbled on a Hydra Matic cab and started welding up the holes after you have been searching for so long to find one isn't it? On the trans cover Tim mentioned, does the front of it seem to "climb the firewall"? or does the front of it end where the floor pans meet the point where firewall starts up? The HydraMatic starter switch would have been about a half inch hole with a skeleto key looking notch at the top and as you mentioned, directly above the headlight switch. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Tim & Greg....let the killing start! That is exactly what this cab was. I knew it was a automatic tranny cab soon after I bought it. I have already welded up the dash hole, and sad to report, transplanted the missing firewall section from my cab to the new one. I had to graft the piece that holds the clutch pedal felt gasket and gas pedal pivot..just like you said. I wasn't aware the Hydramatic cabs were rare. Stuart. | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | If you didn't use the HydraMatic transmission cover, There is a round hole in the floor kinda like the one over master cylinder except larger diameter to be able to check trans fluid. If the hole cover is in danger of getting tossed, let me know and I will try and talk you out of it. Thanks, G.H. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Greg, If I had it, it would be yours.....the tranny cover was missing when I purchased the cab.
Stuart. | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | I appreciate the thought. Thanks anyway. | | |
