3 members (Nick in Manitou, 49 panel, Hotrod Lincoln), 25 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#163217 07/01/2005 5:33 PM
Hey all, I need some help badly, If I keep going the way I am, I'll break my new tinted window glass...Trying to get my vent window assembly back in, and not having the best of luck..Does anyone know any tricks to make it easier?..Trying to take it easy, but fixin to get a little upset..Appreciate any knowledge you could share..Steve
#163218 07/01/2005 6:38 PM
Haven't done that part yet, Steve. My almost completed assembly is bagged and sitting in my warehouse bay 'til I get around to it or the old one falls out of the door.
What I can say is . . . Walk away from it for awhile. Your subconscious mind will be still working on the problem while you do other things and you'll be amazed at the new approaches you'll come up with in the meantime.
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
#163219 07/01/2005 10:17 PM
Steve,
Are you referring to putting the glass back into the vent frame; or, are you referring to putting the vent/window frame back into the door?
Either way, I agree with Larry, walk away from it for a while. Tell us what is going on - many of us have learned the correct swear-words on all aspects of this operation.
If you are having problems getting the frame back into the door, Alan Horvath has a very good explanation of installation of the side window frame and an explanation of installing the vent window frame.
Tim
#163220 07/01/2005 10:24 PM
Thanks Tim..I walked away for this evening..Trying to get the vent window frame assembly back in the door after replacing window glass and all new channels and rubber..Actually, haven't got to the swear words yet, at least not out load..Tomorrows a new day..Later, Steve
#163221 07/01/2005 10:35 PM
I had those things from Alan printed out before, but they must be in a pile somewhere..Anyway, I think I got it figured out..I've been trying to start the vent channel on the top of the window, and working it down..Doesn't work, because the top of the assembly binds on the door..I guess I'll try to get the channel all the way down, and then get it on the glass..Let you know how it turns out..Have a great weekend, Steve
#163222 07/01/2005 11:34 PM
I've had the same fight on my 54 car a few times. I always have to try a few different ways to slither it in place before I find the magic way. It has several tabs and such to catch it when it's 'almost there'.
You should not have to force anything (unless something was bent in the process that is).
One thing that helps me is to NOT put any screws in until all holes line up. I use those small wooden skewers to poke thru the holes to tell when the holes are aligned.
Good Luck!!!
#163223 07/01/2005 11:41 PM
Thanks, I think I'll need the luck, but tonight, I'm cooking smoked salmon on the grill and having a margarita..It'll still be there tomorrow..Enjoy you weekend..Steve
#163224 07/02/2005 4:29 PM
Yahoo!! Got my passenger door all back together.Thanks everyone...All I had to do is talk real nice and take the vent assembly out last night for dinner and drinks.
Next, the driver's door..
Ya'll have a wonderful holiday weekend, I know what I'll be doing, Steve
#163225 07/02/2005 8:10 PM
I luv it when a plan comes together!
Larry Kephart
Boca Raton, Florida
#163226 07/02/2005 8:48 PM
You betcha Larry, just got back in from cleaning channels and painting some frames, the glass is soaking in mineral oil and soapstone in the dining room...After doing the passenger, the driver looked pretty bad..I do have a plan..Take care, Steve
#163227 07/02/2005 10:09 PM
Congratulation, Steve.
Have a good weekend and Independence Day.
Tim
#163228 07/04/2005 6:06 PM
Finished my doors yesterday...All new everything..Put in my Pertronix and coil a couple days ago...
Just started raining here, so I guess it's a perfect time for a test drive in the 54..Happy 4th to all, Steve
#163229 07/04/2005 8:21 PM
did ya get that gas gauge fixed,,rain, boy, we need some here,,,,been out cleaning my truck, I gave up, sweating so bad I kept dripping all over my truck,,Fred
just drive em...........
Redryder pix
My Hotrod
#163230 07/04/2005 8:45 PM
Nope, but got all my info on the table..That is on the top of my list, well that list anyway..Seem to have a lot of lists when you get a little older..We've been real dry here, but this little bit of rain sure is nice..Happy 4th Fred..Steve
#163231 07/04/2005 11:35 PM
It is a bit of a bear getting the vent window assembly in! I seem to recall it not being possible by fitting the main window into the vent window post/felt channel right off the bat.
It's like you have to get it in as far as possible and then get the main window into the channel ... fight a bit ... pray ... coax it, etc., etc. and it finally gets into place.
Not easy ... but possible.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#163232 07/05/2005 12:11 AM
You got that right, Alan...Finished my driver's door yesterday..I figured after getting the passenger door in, it would be easy to get the other one...Wrong..They only go in when they want to..No real step by step, It's just magic or some help from the window gremlins..Take care, Steve
Moderated by  ndkid275, Phak1
