5 members (Otto Skorzeny, Barnfind49, Oldcaliforniakid, kades51, 1 invisible), 65 guests, and 1 robot.
Topics128,050
Posts1,055,671
#162295 09/19/2003 12:58 PM
I have an electric seat from a '69 **** Thunderbird in my '68 Chevy C/10 stepside. Long story. The seat adjust mechanism hasn't worked for a while. The switch is fried. A new switch and pigtail from a later model has the same switch configuration [DPDT rocker/4-way joy toggle/ DPDT rocker.] The scarey thing is the wires on the '69 are color coded the opposite from what I assume is off a '73 (or '83?). Red wires and yellow wires on the pigtail are reversed. Where would I go for **** schematics of this vintage?
Every 25 years I like to rebuild that 292 just for GP
#162296 09/20/2003 2:55 AM
Check your local library, they should have books on the wiring diagrams smile
#162297 09/20/2003 1:18 PM
Thanks. Today, I did get the seat partially working again. Dropped in a later model switch into the earlier switch cradle and shot the worm gear machanisms out w/ liquid wrench teflon lube. I think one of the 3 motors is going bad. It sticks and overheats. Luckily it 's the back tilt function. Fore and aft and front lift are coming back on line.
The library seems a good starting place.
Moderated by  ndkid275, Phak1
