0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2001 Posts: 85 | I have an electric seat from a '69 **** Thunderbird in my '68 Chevy C/10 stepside. Long story. The seat adjust mechanism hasn't worked for a while. The switch is fried. A new switch and pigtail from a later model has the same switch configuration [DPDT rocker/4-way joy toggle/ DPDT rocker.] The scarey thing is the wires on the '69 are color coded the opposite from what I assume is off a '73 (or '83?). Red wires and yellow wires on the pigtail are reversed. Where would I go for **** schematics of this vintage?
Every 25 years I like to rebuild that 292 just for GP
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Check your local library, they should have books on the wiring diagrams
| | | | | Joined: Jun 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2001 Posts: 85 | Thanks. Today, I did get the seat partially working again. Dropped in a later model switch into the earlier switch cradle and shot the worm gear machanisms out w/ liquid wrench teflon lube. I think one of the 3 motors is going bad. It sticks and overheats. Luckily it 's the back tilt function. Fore and aft and front lift are coming back on line. The library seems a good starting place.
