5 members (Lostbuthaulinass, Southerntruck, dt235sd, mick53, carbking), 144 guests, and 0 robots.
Topics128,114
Posts1,056,285
Members48,439
#162227 04/09/2005 2:18 AM
I am trying to find a new radio for my 1950 Chevy half ton. The P.O. had some strange ideas that I have been working through. The hole in the dash is "approx" 7 1/4" x 2 1/4". Is this the original size ? Most newer radio faceplates are just 1/4" to small. Any ideas on what would work?
Also, What about Custom Autosound?
Thanks in advance..
1950 Chevy Truck - Modified!
#162228 04/19/2005 8:55 PM
Any competent car audio shop should be able to sell you some black ABS plastic. As long as the head unit will fit in the hole, they should be able to make you a trim piece to snug your unit into the dash. $20 or so for the kit...
jay
Your lack of preparation is not my emergency
#162229 04/20/2005 7:11 AM
Check out what I did Here
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#162230 04/20/2005 4:17 PM
liljay and Alan,
Thanks for the replies. I like what Alan did with his, and it is pretty close to liljay's idea. MUST be the right idea. Time to start adapting !
Thanks Guy's
#162231 04/21/2005 3:16 AM
Neat solution is cover the radio hole with a factory block-off plate (they often come up on eBay and maybe one or two of the specialist suppliers do them)and mount your radio out of sight in the glovebox. (Don't know where you'll put your gloves but here in CA that's not a problem...) Operate it with a remote.
Moderated by  ndkid275, Phak1
