0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | The first one looks like a GM recirculating heater, which only had a cut-off valve at the water neck. The second is a fresh-air heater. Both were available from the factory or to be dealer installed on a new truck. Neither "should" or "shouldn't" be there, as either was available from GM. www.oldgmctrucks.com has a '54 GMC accessory manual online, most of which is also applicable to Chevys - both heaters are also shown in the Chevy accessory installation manual available from any of the parts suppliers. On second review, that isn't a standard truck recirculating heater, which used a round heater core. The front case looks the same, the back is different. It may be from a car? Anyway, it's definately GM and from the right era. | | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I say if it fits (which it looks like it hit the holes in the firewall spot-on) and you like it, I would use it. It doesn't look familiar to me, but that doesn't mean much. As far as the plumbing, Mr Panel is right. Originally the recirculating heater had no control valve. As I remeber from my accessory installation manual (from '51, so things could have changed), there wasn't even a shut-off. The Deluxe Air-Flow heater had the control valve. But, I think that a control valve would make a nice addition. Like TooMany2Count said, it mounts through the oblong hole. The hose runs from the thermostat housing to the inner nipple of the valve, from the outer nipple to the heater core (probably the upper nipple), then from the heater core to the nipple on the water pump. Leave enough length of hose to loop them out and around to the right inner fender. HTH.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
| | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Thanks, guys. I thought it was odd that bolts were so long (except for the two that the PO shortened with a hacksaw). It seems to me that you really need a control so I think I will install a cheap cable operated heater control valve like this: (AC Delco #155814 about $23) [img] http://www.rockauto.com/ref/ACDelco/15-5814.jpg[/img]
Gord 1954 1/2 ton 235 4 speed
| | | | | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | my 54 which i believe was all stock when i got it does not have a heater control valve. it is not the deluxe cab so i assume it is just a plain old heater - hot water in - hot water out. it does not look like yours but like the others said if it works and fits use it!
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
| | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Thanks, Joe. I think I will run the throttle cable to it. The throttle wasn't connected on the truck - I guess it wasn't needed or they lost the parts at the carb end... Anyhow the "T" on the knob can mean "Temperature" now.  I will have to cut those other two bolts down too.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Gord - the heater you have is the most basic version that was frequently installed by the dealer if a heater was wanted - the same from at least 47-59 - the way you found it is the way they were, as said, "recirculating" heater [I've got a bunch if ya need parts  - freebie, not an ad!] the water flow valve [called a 'Ranco valve', and common to nearly all manufacturers] was on the deluxe heater, which was an option installed at the factory and had a thermostatic capilary tube so you could 'set' the temp and it could automatically keep it at that level - they almost always start to leak in fairly short order, so it's wise to mount it on the engine side of the firewall!! I just got in the 'repair kit' from Balkamp for the Ranco in my TF deluxe heater [just the rubber flapper from inside the valve, and the instructions to dis/re-assemble it!] and put it all on the bench for tomorrow  not sure I'll put it in the stock position inside the heater housing tho' Bill | | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Thanks for the explanation, Bill. The "GM" logo looks generic - I guess they put them in a variety of applications. And thanks for the offer of parts. The core was checked at the rad shop and I checked out the motor; both were OK and that's about all that can go wrong with it - pretty basic!
| | | | | Joined: May 2000 Posts: 49 Member | | Member Joined: May 2000 Posts: 49 | Guys I'm tagging onto this thread 'cause it might be useful for someone and me?!
I have NO heater at all and want one. Lacking the heater, controls etc. What's a good place to look for it all? I am not opposed to something like what Chevy Duty sells as it's 12 volt and I'm just about "there". Thoughts?
1951 1/2 ton "Buck" Recently lobotomized for your safety.
| | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Your heater and the little parts of your truck we can see look real good. Post some pics of the rest of the truck!
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Apr 2004 Posts: 11 New Guy | | New Guy Joined: Apr 2004 Posts: 11 | My 59 GMC had an inline brass shut off spliced into one of the heater hoses. Some old cars also had them too.you had to open the hood and manually shut it off . If everything's coming your way , your in the wrong lane... 1958 GMC Shorty | | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | Great job on the heater. I'm restoring a 46 1/2 ton and the heater is similar. One of the fan motors even works. I don't know how they survived the winters out here with these small heaters. Bob T Moose Jaw | | | | | Joined: Apr 2005 Posts: 151 Member | | Member Joined: Apr 2005 Posts: 151 | [QUOTE]Originally posted by Fran and Gord: [QB] I think I will install a cheap cable operated heater control valve AC Delco #155814 about $23 Exactly what I installed in my 54, Gord. Works fine. Well I think it does. Never yet had to open it here in Kaliforny. If it's chilly out I close windows and cowl vent and bask in the engine heat. Christian | | |
