| | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | Anyone installed one of the glass headliners? I am concidering buying one for my 52. If you possibly could send or post a picture....I sure would appreciate it. I've never seen one in person (or picture). THANKS | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I installed a fiberglass headliner in my 37 and it fit good,I am not too familiar with the AD trucks but if it has a center brace to hold up the original you might have to remove it. My 37 had a brace that screwed in and I had to remove it for the glass headliner to fit properly,who is the manufacture?. Jeff | | | | | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | Thanks for the reply....there are several supliers of the fiberglass headliner,not sure of the manufacturer. So, your's is one piece Jeff? The stock AD liner is two pc. with a center bow. | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Mine is a single piece headliner,when I was looking into headliners I found out that some of the cardboard liners required forming so I went with the glass one. I covered mine and before covering it I installed it to mark where the needed holes were to be and covered it with cloth matching the seats. Jeff | | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | What company did you get your glass headliner from for your 37? Seen a few on line and was wondering how the fit might be. Why exactly did you have to remove the center brace? | | |
