2 members (VicZ, doyle1950), 143 guests, and 1 robot.
Topics128,087
Posts1,055,974
Members48,430
#162153 03/15/2004 12:09 AM
At the back of the window trim, does the felt / metal strip curve up the back some? If so how far? Anyone have a pic showing this?
Thank You
#162154 03/15/2004 2:02 AM
Oly Offline
I'm going to move this one to "Interiors". So follow it there and answer it for him.
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
#162155 03/15/2004 3:37 AM
It does curve up some. Of the hundreds of pic I have of my rebuild, I don't have a good shot of that. If you bought replacement pieces they should be correct.
#162156 03/15/2004 3:42 AM
I'm not exactly sure what you're talking about ... but might THIS help?
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#162157 03/15/2004 9:24 PM
Some people call those the "catwhiskers", and originally, they did curl up, both fore and aft. But the reproduction ones, which are the only ones available, do not. As you can see, they are just one long piece. You will need to cut some off. You did not ask, but if you are interested, the best way to attach them is with the smallest flat head screws you can find. The screwhead will vanish into the felt. Much easier than trying to attach with staples as original.
#162158 03/18/2004 2:13 PM
52GMC,
The ones I got from Jim Carter curve up at one end; the ones I received from Chevy Duty are straight.
As Brian said, the straight ones can be easily adapted; and, screwing them one is much easier than trying to staple them.
Tim
#162159 03/18/2004 9:12 PM
The ones I got curl up at one end, too -- matches the trim nicely. And screwing them in is definitely the way to go! Much easier ... plus, I plan on covering my trims with vinyl when I do my interior this Spring and Summer, and with those pieces screwed in, it makes it easy enough to remove them, cover the trim, and replace them.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
Moderated by  ndkid275, Phak1
