1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 24 Member | | Member Joined: Dec 2001 Posts: 24 | At the back of the window trim, does the felt / metal strip curve up the back some? If so how far? Anyone have a pic showing this?
Thank You | | | | | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | I'm going to move this one to "Interiors". So follow it there and answer it for him.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
| | | | | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | It does curve up some. Of the hundreds of pic I have of my rebuild, I don't have a good shot of that. If you bought replacement pieces they should be correct. | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I'm not exactly sure what you're talking about ... but might THIS help?
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Some people call those the "catwhiskers", and originally, they did curl up, both fore and aft. But the reproduction ones, which are the only ones available, do not. As you can see, they are just one long piece. You will need to cut some off. You did not ask, but if you are interested, the best way to attach them is with the smallest flat head screws you can find. The screwhead will vanish into the felt. Much easier than trying to attach with staples as original. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 52GMC,
The ones I got from Jim Carter curve up at one end; the ones I received from Chevy Duty are straight.
As Brian said, the straight ones can be easily adapted; and, screwing them one is much easier than trying to staple them.
Tim | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | The ones I got curl up at one end, too -- matches the trim nicely. And screwing them in is definitely the way to go! Much easier ... plus, I plan on covering my trims with vinyl when I do my interior this Spring and Summer, and with those pieces screwed in, it makes it easy enough to remove them, cover the trim, and replace them.
