5 members (Steelonsteel, Tyler Watts, RaNfLaS, rfs56trk, DadsFirstPickup), 101 guests, and 2 robots.
Topics128,048
Posts1,055,663
#162089 02/27/2005 6:32 PM
It has been far too long between teardown and re-assembly. Does the speedo in a '51 go in the right...or left hole. Seems to look OK in either...but i dont wanna be a dork and put it in the wrong hole!!!!!
#162090 02/28/2005 3:02 AM
Just finished reinstalling mine. It goes on the right. Your wiring harness will tell you the same thing when you go to install it. If you put the gauge cluster on the right the wiring won't reach it. The speedo cable hole in the firewall will line up better if the speedo is in the right (RIGHT) side.
Moderated by  ndkid275, Phak1
