| | | Forums66 Topics128,026 Posts1,055,399 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2000 Posts: 30 Member | | Member Joined: Jun 2000 Posts: 30 | It has been far too long between teardown and re-assembly. Does the speedo in a '51 go in the right...or left hole. Seems to look OK in either...but i dont wanna be a dork and put it in the wrong hole!!!!! | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Just finished reinstalling mine. It goes on the right. Your wiring harness will tell you the same thing when you go to install it. If you put the gauge cluster on the right the wiring won't reach it. The speedo cable hole in the firewall will line up better if the speedo is in the right (RIGHT) side. | | |
