| | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 6 Member | | Member Joined: May 2004 Posts: 6 | Speedo is dead. Are the two screws on the back the only ones holding the assembly in place. Thanks in advance!
Vos veritas liberabit.
| | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | I think there are three. One on each side and one on top. They are short stubby screws. This will remove it from the cluster. Once out you can take out the two screws with the rubber washers and that will take it out of the speedo housing. If you want photos let me know I have an extra one that is in peices.
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | |
