Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
Finishing up on my cooling system refurbish. After a successful test using water, I drained to fill with antifreeze. The block petcock was just dripping, and I had seen folks suggesting removing it and poking around a bit to get it flowing better. Well, I got myself in a pickle with the brass fitting being stubborn. The petcock is now boogered up beyond all recognition. I'm nervous I will twist it in half before it breaks loose. I have used lots of PB Blaster and a bit of heat. A wrench is no longer an option, and the vice grips are not playing nice. If I twist it in half, I guess I my only choice will be to drill it out and run a tap to clean out the threads. Yuck.
Thanks for any suggestions you might have for removing what's left of the petcock.
- Jeff 1949 Chevy 5 window 3100 with 216 Getting Dad's '49 farm truck backroad worthy!
I’ve seen Parrot Jaw Vise-grips used on brake fittings on youtube, but I haven’t gotten mine yet. Could be the cat’s meow for this type of thing……or the dog’s breakfast , depending!
~Charley 1954 Chevy 3100 with 235 “Bud” Follow along in the DITY 1963 Chevy half ton stepside short box 230 1954 GMC 3 ton 302 And several more Chevy camper and work trucks 1979 1987 1996
Crank down tight on that sucker with vice grips and it'll come out. You need to get the vice grips tight enough so they don't slip. You've already destroyed the petcock, and will need to replace it anyway. I'd suggest a square head plug instead of a petcock.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
You are trying to turn the big nut that's directly in the block and not the remains of the petcock, right?
1950 Chevrolet 3100 (Ol' Roy)
Heat up the area around it, let cool, and maybe give it a second heating and cooling. Brass will expand faster than the cast iron, so it needs to cool off. It's a pipe thread, so once it cracks loose, it should come right out. If you twist it off, don't drill it out till you try an easy out. Most brass fittings come out before extensive drilling is needed. If you must drill, go big enough to start a pipe tap and just rethread it, the tap should pull out the remaining fitting pieces, do go any deeper than necessary. Plug it next time, no real need for a petcock. I never could get mine to quit seeping, it now has a plug.
I use Gedore locking pliers for stubborn brass. Years ago I brought them along from Germany when I visited relatives, but they are available here now. I have them in various shapes and sizes, but this is the one that works the best on rounded brass.
I won...this battle anyway. Nothing a little persuasion and a chiropractor can't handle.
Once removed I filled the system with water and it just dripped. Coat hanger made instant difference! After poking around about 4" and several rinses it flows really great and clear.
Thanks for the suggestions! I used a bit of all of them!
In the future I would avoid PB Blaster...actually I call it PT Barnum Blaster. It used to be good stuff but about 6 years ago they did something and it has not been much better than plain oil since then. They sell some different versions now but it doesn't work like it did. Kroil is still pretty good. Or you can mix 50% automatic transmission oil and 50% acetone. That will work and it might cost less...don't know what acetone costs now.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
