Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Guitplayer, TexasFarmTruck, 55shaker, mick53), 183 guests, and 4 robots.
Topics128,286
Posts1,058,659
Members48,493
Looking for a door lock for a '41 Chevy truck
See post in your original thread.
41 chev - The door latch with lock mechanism pictured with the circle is for the drivers door to the best of my knowledge, with that lock activated from the inside by turning the "T" knob from inside the cab.
That part is absent from the passenger side latch assembly as the key lock cylinder in the handle operates the lock pieces in that side of the handle/latch and lock. The passenger side latch/lock assembly doesn't include an inside the cab locking mechanism like the drivers door side does.
So to hopefully understand what you are seeking, which door latch/lock assembly are you looking for? Drivers side or passenger side?
In your picture, it looks like you have both already and they look to be functional. headscratch
~ Dan
1951 Chevy 3 window 3100
My truck doesn't have a lock cylinder on both handles that is why I'm confused
For 1941, Chevy trucks had a locking door handle on the passenger side (only) You used a key that was inserted into the handle to lock the handle itself. There was no mechanism in the latch plate. All that changed in 1942( thru 1946) when a separate lock was installed in the passenger door below a non-locking door handle. As a result, the locking door handle and the correct 1941 latch plate are rare.
All the trucks used a non-locking door handle on the driver’s side as Dan described above.
Thanks for the info now I need to find a locking handle
If you are looking for a 2nd locking handle for the drivers side, it will not solve the "convenience" problem that you might be chasing. You cannot lock the passenger door from the inside. If you do not have a locking handle, I might be able to help. I think Jim Carter sells the Tee Handle locking toggle for the drivers door.
Mike Russell
Columbia, Missouri
573 864 6539 call or text or [email protected]
1936 1-1/2 Ton (RD) Stake Body Original
I have the "T" handle for the drivers door. I need a locking door handle for passenger side
