Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
The bolts are 3/8-24 which is common but the head design is not common. There are several dozen different head designs around. GMC inline haven't been available for a long time. I have never tried using a different rod bolt. Are you missing yours or do you just want new ones? In case you are missing the bolts, here is what they look like.
Same bolts & nuts GMC six cylinder 1939 thru 1960 228, 236, 248, 256, 270 and 302 engines. Bolts are part # 2192821 & nuts are 560545.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
I install 3/8-24 HeliCoils in Chevy connecting rods and use recycled NASCAR rod bolts. The same thing can probably be done with GMC rods. There is approximately 150% thread engagement over using bolts and nuts, and the ARP style bolts are MUCH stronger than the originals. The big ends of the rods will need to be reconditioned, but that's always part of a good quality engine rebuild. Ignore the torque specifications and tighten the bolts to get approximately .005" stretch on the bolts.
I need 4 bolts and I have some spare rods that I can take the bolts out of, but thought if I could get new ones that would work, I would do that. I would rather not say WHY I need the bolts, it would be too embarrassing!!!!!
Although I usually recommend new rod bolts, I reused old rod bolts in a lot of engines including Y-Blocks and GMC. I have several 302 engines that I am going to build and I am going to use reuse old bolts. Reused rod bolts stood up to constant full throttle back in the day when we used 270 and 302 engines in tank wagons. We usually reringed engines once with file to fit rings. Twice if they would still take file to fit rings. And then we bought new short blocks from GMC. Of course the new short blocks had new bolts. I looked at the Government Manual. They only give torque specs for reusing bolts.
Replacing rod bolts with original rod bolts should save you from resizing the rods. On most rods, if you change to aftermarket rod bolts, resizing is a must. The new bolts fit different and change the shape of the opening.
Why would anybody trust a 70 year old connecting rod without reconditioning the big end, regardless of which bolts are being used? Maybe because they don't have a Sunnen hone? I keep forgetting that, since I own two of them! LOL! Jerry
I helped my father maintain GMC tank wagons when I was in school. I owned trucks for 62 years and I finally auctioned them off earlier this year so I am back to tinkering with 70 year old iron. I always measured the big hole and if it was in spec, I reused it. GMC rods are between 2.4563 and 2.4568. I have measured a lot of rods from Cummins as well as GMC and Y-Block. I rejected very few rods. And in all those years I only had one 2 rods to go out the side of the block. Both were in trucks that I bought used that had engines built by a machine shop.
