Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Steveoreno, WICruiser, Phak1), 171 guests, and 5 robots.
Topics128,275
Posts1,058,574
Members48,492
Are new rod bolts available for the 270 GMC will SB chevys fit?
The bolts are 3/8-24 which is common but the head design is not common. There are several dozen different head designs around. GMC inline haven't been available for a long time. I have never tried using a different rod bolt. Are you missing yours or do you just want new ones? In case you are missing the bolts, here is what they look like.
Same bolts & nuts GMC six cylinder 1939 thru 1960 228, 236, 248, 256, 270 and 302 engines. Bolts are part # 2192821 & nuts are 560545.
I install 3/8-24 HeliCoils in Chevy connecting rods and use recycled NASCAR rod bolts. The same thing can probably be done with GMC rods. There is approximately 150% thread engagement over using bolts and nuts, and the ARP style bolts are MUCH stronger than the originals. The big ends of the rods will need to be reconditioned, but that's always part of a good quality engine rebuild. Ignore the torque specifications and tighten the bolts to get approximately .005" stretch on the bolts.
www.ebay.com/itm/198397402910?
www.ebay.com/itm/366444706583?
I need 4 bolts and I have some spare rods that I can take the bolts out of, but thought if I could get new ones that would work, I would do that. I would rather not say WHY I need the bolts, it would be too embarrassing!!!!!
Although I usually recommend new rod bolts, I reused old rod bolts in a lot of engines including Y-Blocks and GMC. I have several 302 engines that I am going to build and I am going to use reuse old bolts. Reused rod bolts stood up to constant full throttle back in the day when we used 270 and 302 engines in tank wagons. We usually reringed engines once with file to fit rings. Twice if they would still take file to fit rings. And then we bought new short blocks from GMC. Of course the new short blocks had new bolts. I looked at the Government Manual. They only give torque specs for reusing bolts.
