Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (UtahYork, klhansen, Otto Skorzeny, carbking, SNOYL, ndkid275), 108 guests, and 2 robots.
Topics128,286
Posts1,058,539
Members48,491
#1614692 11/03/2026 11:20 PM
Sjm
Offline
I want to install tail house 3 speed adapter on my 1953 Chevy 3100 and would like so feed back if any one has install one. Of these before.
Sjm #1614701 11/04/2026 12:02 AM
Not sure what kind of "adapter" you mean? Are you looking at changing your truck from a column shifter to a floor mounted style (mounted to the transmission case/tailshaft housing) shifter, or something else??? headscratch
~ Dan
1951 Chevy 3 window 3100
Sjm
Offline
I would like to keep 3 on tree with stock trans. With tail house adapter. Replace rearend with open drive shaft.
Actually the easiest way to do that is to replace the closed drive shaft SM318 3 speed with a later open drive SM318 from a Task Force truck.
From my previous thread reading, I'm pretty sure others have done that very swap. Perhaps those that have will chime in with their experience and input? thumbs_up
~ Dan
Find a 1955 or later transmission from a Chev pickup or passenger car. It will have an open drive shaft and it will be a better transmission. The old "peanut" transmissions were never offered with an open drive shaft and no one ever produced one.
Sjm #1615033 11/08/2026 11:39 PM
Since you'll need to fabricate a custom driveshaft anyway, try swapping to a Saginaw 3 speed with a synchronized 1st. gear. With a little creative fabri-cobbling on the shift linkage you'll still be able to use your original column shift setup.
Sjm #1615040 11/09/2026 12:44 AM
Slm,
I see that you are a few posts shy of graduating from "Moderated Status".
Make a few more posts so that we can exchange via PM.
I have exactly what Hotrod Lincoln is describing. A 1965 Saginaw 3 speed transmission with all of the shifter arm and shifting linkages modified for tree on the tree in an AD truck.
Send me a PM once you are no longer in moderated status for more info.
Sjm
Offline
The reason I wanted to use my stock trans. Is I just rebuilt .
An unfortunate set of circumstances Sjm. frown
BTW - Your next post won't require moderation approval, so you'll be able to send 52Carl a PM if your inclined to pursue his offer to share information. wink
~ Dan
A good machine/welding shop could fabricate a conversion to open driveline for your original transmission, but the cost and labor time would be considerable. Swapping to a later model transmission would definitely be a better option.
Sjm #1615163 11/10/2026 11:49 PM
Sjm
Offline
Thanks for your feed back. I will just drive it like it is until it breaks.
This is the adapter Chevs of the 40’s offers. But at $1044 a bit pricey. I think this is what he is asking if anyone has used, I am curious also.
Sjm
Offline
Yes that is the adapter I was talking about. I watched a short video about it.
Sjm - I guess I hadn't seen this offering from Chev's of the 40's. Looks like that's what you are looking for, but boy is that a Big Chunk Of Change$$$ Ouch!
~ Dan
That one looks like it uses as extension housing and a stub shaft that plugs into the original universal joint. Wouldn't it be simpler (and shorter) to just use the front half of the torque tube u joint with a flange that bolts to it, since the replacement housing doesn't pivot? That would also eliminate one source of vibration and possible failure.
I had no idea anyone was offering something like this. I have a 54 that I'm considering open drive shaft, but I have several 55 and newer transmissions and some 55 or newer rears. I still think that is a much simpler approach. And much cheaper. I have done it before. I weld the swing suspension while the closed drive shaft is still in it and then use the 55 and newer drive shaft.
Do you have a link to the video or can you tell me where to find it?
Rick - I believe this may be the video "Sjm" is referring to Open Drive Tail Shaft Explained
Looks like these folks may be building/supplying these for resale through Chev's of the 40's?
~ Dan
Why not just mate a short Turbo 350 extension housing and output shaft to the torque tube transmission case, and make an adapter flange to mate with the front section of a torque tube universal joint? Then the speedometer drive, slip yoke bushing, fluid seal, and slip yoke will all be over the counter parts. That would drop the price by a bunch!
Sjm
Offline
Sjm #1615298 11/12/2026 11:04 PM
Add one more project to the "round tuit" list!
LOL!
Sjm #1615465 11/16/2026 10:52 PM
Upon doing some preliminary measurements, it looks like adapting a short TH 350 output shaft and extension housing to the torque tube transmission is doable- - - -at a considerably lower cost than that Rube Goldberg adapter device.
