1 members (Ponchogl),
82
Mod | | | Forums66 Topics128,268 Posts1,058,283 Members48,483 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2026 Posts: 5 'Bolter | | 'Bolter Joined: Oct 2026 Posts: 5 | I want to install tail house 3 speed adapter on my 1953 Chevy 3100 and would like so feed back if any one has install one. Of these before. | | | | | Joined: Sep 2009 Posts: 6,183 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,183 | Not sure what kind of "adapter" you mean? Are you looking at changing your truck from a column shifter to a floor mounted style (mounted to the transmission case/tailshaft housing) shifter, or something else???
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Oct 2026 Posts: 5 'Bolter | | 'Bolter Joined: Oct 2026 Posts: 5 | I would like to keep 3 on tree with stock trans. With tail house adapter. Replace rearend with open drive shaft. | | | | | Joined: Sep 2009 Posts: 6,183 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,183 | Actually the easiest way to do that is to replace the closed drive shaft SM318 3 speed with a later open drive SM318 from a Task Force truck. From my previous thread reading, I'm pretty sure others have done that very swap. Perhaps those that have will chime in with their experience and input?
| | | | | Joined: Jan 2008 Posts: 4,983 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,983 | Find a 1955 or later transmission from a Chev pickup or passenger car. It will have an open drive shaft and it will be a better transmission. The old "peanut" transmissions were never offered with an open drive shaft and no one ever produced one. | | | | | Joined: Feb 2004 Posts: 29,937 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,937 | Since you'll need to fabricate a custom driveshaft anyway, try swapping to a Saginaw 3 speed with a synchronized 1st. gear. With a little creative fabri-cobbling on the shift linkage you'll still be able to use your original column shift setup.
| | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | Slm, I see that you are a few posts shy of graduating from "Moderated Status". Make a few more posts so that we can exchange via PM. I have exactly what Hotrod Lincoln is describing. A 1965 Saginaw 3 speed transmission with all of the shifter arm and shifting linkages modified for tree on the tree in an AD truck. Send me a PM once you are no longer in moderated status for more info.
| | | | | Joined: Oct 2026 Posts: 5 'Bolter | | 'Bolter Joined: Oct 2026 Posts: 5 | The reason I wanted to use my stock trans. Is I just rebuilt . | | | | | Joined: Sep 2009 Posts: 6,183 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,183 | An unfortunate set of circumstances Sjm.  BTW - Your next post won't require moderation approval, so you'll be able to send 52Carl a PM if your inclined to pursue his offer to share information.
| | | | | Joined: Feb 2004 Posts: 29,937 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,937 | A good machine/welding shop could fabricate a conversion to open driveline for your original transmission, but the cost and labor time would be considerable. Swapping to a later model transmission would definitely be a better option. Jerry
