7 members (Ribside, UtahYork, FAST55, Donf, dt235sd, Otto Skorzeny, 1 invisible), 231 guests, and 4 robots.
Topics128,256
Posts1,057,997
Members48,479
#1614692 11/03/2026 11:20 PM
Sjm
Offline
Moderated
Moderated
I want to install tail house 3 speed adapter on my 1953 Chevy 3100 and would like so feed back if any one has install one. Of these before.
Sjm #1614701 11/04/2026 12:02 AM
Not sure what kind of "adapter" you mean? Are you looking at changing your truck from a column shifter to a floor mounted style (mounted to the transmission case/tailshaft housing) shifter, or something else??? headscratch
~ Dan
1951 Chevy 3 window 3100
Sjm
Offline
Moderated
Moderated
I would like to keep 3 on tree with stock trans. With tail house adapter. Replace rearend with open drive shaft.
Actually the easiest way to do that is to replace the closed drive shaft SM318 3 speed with a later open drive SM318 from a Task Force truck.
From my previous thread reading, I'm pretty sure others have done that very swap. Perhaps those that have will chime in with their experience and input? thumbs_up
~ Dan
