| | | Forums66 Topics128,286 Posts1,058,539 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2016 Posts: 1 Moderated | | Moderated Joined: May 2016 Posts: 1 | Has anyone swapped out the 207 in a 1933 truck? I was thinking of the 235. My concern is finding a transmission that will fit the engine and also fit inside the space I have. I have the original 207 from that truck that I sent out for rebuild and the guy just gave me years of excuses so I finally took it back but its in pieces now, with some things missing. Along the way I bought a second engine for him to use for any needed parts and that one is still pretty much in tact. I have given up on rebuilding this engine as all the quote I have gotten are very high and the time will take another year or two. So I'm giving up on that idea. Any help or advice would be greatly appreciated.
Thanks. | | | | | Joined: Feb 2004 Posts: 29,956 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,956 | The 207 is a few inches longer than the 216/235/261 engines, and there are a lot more differences to consider. You would probably be better off swapping in a complete engine/bellhousing/transmission setup than trying to adapt a later model stovebolt engine to the early drive train. Things like clutch and brake pedal mounts, etc. would also need to be modified. If you have enough bits and pieces to build the original engine, maybe with some modern internal upgrades, it might be a better way to approach the situation. I do things like convert Babbit bearing engines to different connecting rods and bearings, and convert spray-lube crankshafts to pressure lubrication, etc. That approach retains the original appearance of the engine while putting more modern, less expensive parts on the inside. Jerry
