Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (greenie-reddy, dt235sd, frogfarmer, pauld, Bill Hanlon), 116 guests, and 2 robots.
Topics128,279
Posts1,058,593
Members48,492
#1615368 11/14/2026 2:39 PM
I cannot find a new locking tab for either the front engine mount plate for the 2 through bolts or the locking plate for the flywheel. Or is everyone just using loctite. The ones I remove are too far gone.
Shady
1950 Model 3104 5-Window
"Back In Time"
Follow in the DITY
Shade Baby #1615381 11/14/2026 6:50 PM
I believe that you'd be fine with loctite. Just be sure that the bolt holes and bolts are oil free before applying the loctite and installing the bolts.
You might also consider also external star lock washers. One vendor includes those with replacement flywheel bolts.
