| | | Forums66 Topics128,279 Posts1,058,593 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2023 Posts: 284 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 284 | I cannot find a new locking tab for either the front engine mount plate for the 2 through bolts or the locking plate for the flywheel. Or is everyone just using loctite. The ones I remove are too far gone.
Shady | | | | | Joined: May 2015 Posts: 11,282 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,282 | I believe that you'd be fine with loctite. Just be sure that the bolt holes and bolts are oil free before applying the loctite and installing the bolts. You might also consider also external star lock washers. One vendor includes those with replacement flywheel bolts.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
