1 members (1 invisible), 111 guests, and 5 robots.
Topics128,261
Posts1,058,342
Members48,485
#1614692 11/03/2026 11:20 PM
Sjm
Online: Content
S Online: Content
I want to install tail house 3 speed adapter on my 1953 Chevy 3100 and would like so feed back if any one has install one. Of these before.
Sjm #1614701 11/04/2026 12:02 AM
Not sure what kind of "adapter" you mean? Are you looking at changing your truck from a column shifter to a floor mounted style (mounted to the transmission case/tailshaft housing) shifter, or something else??? headscratch
~ Dan
1951 Chevy 3 window 3100
Sjm
Online: Content
S Online: Content
I would like to keep 3 on tree with stock trans. With tail house adapter. Replace rearend with open drive shaft.
Actually the easiest way to do that is to replace the closed drive shaft SM318 3 speed with a later open drive SM318 from a Task Force truck.
From my previous thread reading, I'm pretty sure others have done that very swap. Perhaps those that have will chime in with their experience and input? thumbs_up
~ Dan
Find a 1955 or later transmission from a Chev pickup or passenger car. It will have an open drive shaft and it will be a better transmission. The old "peanut" transmissions were never offered with an open drive shaft and no one ever produced one.
Sjm #1615033 11/08/2026 11:39 PM
H Online: Content
Since you'll need to fabricate a custom driveshaft anyway, try swapping to a Saginaw 3 speed with a synchronized 1st. gear. With a little creative fabri-cobbling on the shift linkage you'll still be able to use your original column shift setup.
Sjm #1615040 11/09/2026 12:44 AM
Slm,
I see that you are a few posts shy of graduating from "Moderated Status".
Make a few more posts so that we can exchange via PM.
I have exactly what Hotrod Lincoln is describing. A 1965 Saginaw 3 speed transmission with all of the shifter arm and shifting linkages modified for tree on the tree in an AD truck.
Send me a PM once you are no longer in moderated status for more info.
Sjm
Online: Content
S Online: Content
The reason I wanted to use my stock trans. Is I just rebuilt .
An unfortunate set of circumstances Sjm. frown
BTW - Your next post won't require moderation approval, so you'll be able to send 52Carl a PM if your inclined to pursue his offer to share information. wink
~ Dan
H Online: Content
A good machine/welding shop could fabricate a conversion to open driveline for your original transmission, but the cost and labor time would be considerable. Swapping to a later model transmission would definitely be a better option.
Sjm #1615163 11/10/2026 11:49 PM
Sjm
Online: Content
S Online: Content
Thanks for your feed back. I will just drive it like it is until it breaks.
This is the adapter Chevs of the 40’s offers. But at $1044 a bit pricey. I think this is what he is asking if anyone has used, I am curious also.
Sjm
Online: Content
S Online: Content
Yes that is the adapter I was talking about. I watched a short video about it.
Sjm - I guess I hadn't seen this offering from Chev's of the 40's. Looks like that's what you are looking for, but boy is that a Big Chunk Of Change$$$ Ouch!
~ Dan
H Online: Content
That one looks like it uses as extension housing and a stub shaft that plugs into the original universal joint. Wouldn't it be simpler (and shorter) to just use the front half of the torque tube u joint with a flange that bolts to it, since the replacement housing doesn't pivot? That would also eliminate one source of vibration and possible failure.
