3 members (Southerntruck, Charles in CA, 1 invisible), 86 guests, and 4 robots.
Topics128,263
Posts1,058,131
Members48,482
#1614575 11/02/2026 12:21 PM
Hello, has anyone tried rust removal with laser guns? I get advertisements about thus from CAD4000 to 12,000. I am thinking to get professional blasting equipment and rent a compressor, but this laser setup seems to be so much cleaner.
JoergK.
1948 GMC Model 9434 Frame rebuild
1953 Chevrolet 1314 1/2 ton rebuild
Follow along in the DITY Bay
Lots of video's on laser rust removal. They seem to work really good on heavy iron but I have not seem sheet metal cleaned yet. One would have to price one out, then figure how much electricity it's going to take to run it all day. It would be nice to have one, no sand to clean up. Keith Rucker has a few video's out with his new laser - Laser cleaning
27 years ago, when I first started on my truck, I rented a big air compressor and pressure blaster to clean the sheet metal and frame. It went OK, of course it was wet and misting all day so I had to rig up a tent asap. I cleaned up sand for weeks after, and managed to warp some sheet metal. I have a small 50 lb pressure blaster I use for cylinder heads, blocks, and other engine pieces. I would not want to do a frame or cab. The good media is expensive, and cheaper coal slag is way to course for fine metal. For iron and heavy steel, the coal slag is great. No matter what type of media you use, it's hot and dirty work, and not all that great for your lungs.
Sure would be a lot less clean up with a laser.
My thought is for axles, heavy stuff & corners of the cab etc. that are hard to get into. Large areas are easy with sanding. Nicks & crannies are the problem. Do I spend $5-8,000 on blasting equipment and have the medium everywhere or go laser?
JoergK.
AD Addict & Tinkerer
You could always farm that out to a local blaster that’s done truck body's and frames. It would be allot cheaper than buying the equipment and you’ll have no mess. An experienced blaster will not warp your sheet metal. If you go that route, get some recommendations from locals.
Phil
Project Journals
Stovebolt Gallery Forum
There are some videos from Halffass customs from Winnipeg on taking the rust off as well as Carter autorestyling from Maymont Saskatchewan who just recieved one to test out on his Channel .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
What Phil said about hiring a professional blaster. That's what I did. He came to my house, set up a tent and blasted my cab, which I had on a rotisserie. It did take him all day, but when he was gone, he had cleaned everything up, except for a tiny bit of sand that was in some of the nooks and crannies of the cab. I was able to shoot primer on the cab shortly afterwards. It was a little pricey $1200 IIRC, but worth it. I had him do the frame and a bunch of other stuff at his lot as well. His rig is mounted on a trailer and he has supplied air protection.
A friend bought a laser rust removal setup, but I have not seen it work yet. They had a first hand demonstration before they bought it. I think it was way more than what I paid the blaster, I'm recalling over $10k.
Do the laser blasters also do welding? I've seen a few laser welders that look pretty good. Ed China on the web laser cleaned a whole Range Rover frame, then made a huge tank and used Evap-o-rust to get the insides. Pretty neat video, but super expensive. https://www.youtube.com/@eddchina
Like I used to tell my high school auto body students- - - - -"There's three kinds of body work- - - - -good, quick, and cheap. You can only pick two, or sometimes only one!" Ditto for rust removal!
Okay, I agree with having the big stuff done custom. Now the smaller, more intricate pieces of metal, where I thought the laser would be handy, like can, fenders, wheel well covers, box sides, tailgate, bolts etc.
I seem to be doing more of this with four pickups & one 3 ton (Fargo) in the storage shop to come, cause I like fixing old things. So $5-6,000 would scare me, but not for junk.
Still thinking!
JoergK.
