| | | Forums66 Topics128,279 Posts1,058,593 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 1995 Posts: 5,762 24601 | | 24601 Joined: Nov 1995 Posts: 5,762 | I can't seem to get this right ... at the connection of the exhaust pipe to the exhaust manifold, do I use the gasket and the donut or just the donut? Or just the gasket?
I had just the donut on after the head rebuild, but one of the nuts backed off coming home from a show over the Summer and now the exhaust pipe is just dangling from the one stud. I think the donut is gone. I have two gaskets and a new donut ready to go.
Thanks, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jan 2022 Posts: 2,526 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,526 | This answer isn't old truck specific, but I believe the donut is designed to be crushed, but would not allow the manifold and the (whatever you call the movable piece on the exhaust pipe) to crush so much to touch. Therefore the gasket & donut combination would never use the gasket to seal anything.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Nov 1995 Posts: 5,762 24601 | | 24601 Joined: Nov 1995 Posts: 5,762 | Bill -- That's what I thought, too. So why is the gasket even there if it doesn't do anything?? I left it off last time. Leave it out this time, too?? Or stick it on the exhaust pipe side to seal the collar?
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Dec 2025 Posts: 24 'Bolter | | 'Bolter Joined: Dec 2025 Posts: 24 | Bill -- That's what I thought, too. So why is the gasket even there if it doesn't do anything?? I left it off last time. Leave it out this time, too?? Or stick it on the exhaust pipe side to seal the collar? The gasket was used on earlier engines in place of the doughnut, and both styles are usually included in the manifold gasket set. | | | | | Joined: Nov 1995 Posts: 5,762 24601 | | 24601 Joined: Nov 1995 Posts: 5,762 | Thanks DT -- That's what I needed to know! Off to the garage!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | I have run into a mismatch of manifold and exhaust pipe types before where the manifold flange was flat to accept a flat gasket, while the exhaust pipe was made for a donut. I didn't want to go through the hassle of changing out one or the other to fix the problem. What I did find out was that someone makes a donut which is flat on one side and chamfered on the other and fixed the problem. I don't know who offers those. I believe that incidentally I acquired it at a swap meet in box of miscellaneous parts.
| | | | | Joined: Nov 1995 Posts: 5,762 24601 | | 24601 Joined: Nov 1995 Posts: 5,762 | Everything matched up and the truck is quiet again!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2004 Posts: 29,960 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,960 | The manifold designed for the donut has a 45 degree chamfer on the inside diameter, and the exhaust pipe should have a corresponding flare at the end of the pipe. The companion flange that clamps the pipe to the manifold slides freely on the pipe and it does not touch the manifold. Exhaust pipes intended for earlier manifolds that use a flat gasket have the flange welded to the pipe, and it sandwiches the gasket tight between the manifold and the flange. These double height brass nuts help the flange stay tight: www.ebay.com/itm/134070873892?Most auto parts stores stock them, so there's no need to mail order. The thread size is 3/8-16. Jerry
