Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (dt235sd, frogfarmer, pauld, Bill Hanlon), 122 guests, and 2 robots.
Topics128,279
Posts1,058,593
Members48,492
#1614330 10/30/2026 4:12 PM
24601
24601
I can't seem to get this right ... at the connection of the exhaust pipe to the exhaust manifold, do I use the gasket and the donut or just the donut? Or just the gasket?
I had just the donut on after the head rebuild, but one of the nuts backed off coming home from a show over the Summer and now the exhaust pipe is just dangling from the one stud. I think the donut is gone. I have two gaskets and a new donut ready to go.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
B Online: Content
This answer isn't old truck specific, but I believe the donut is designed to be crushed, but would not allow the manifold and the (whatever you call the movable piece on the exhaust pipe) to crush so much to touch. Therefore the gasket & donut combination would never use the gasket to seal anything.
24601
24601
Bill -- That's what I thought, too. So why is the gasket even there if it doesn't do anything?? I left it off last time. Leave it out this time, too?? Or stick it on the exhaust pipe side to seal the collar?
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
D Online: Content
The gasket was used on earlier engines in place of the doughnut, and both styles are usually included in the manifold gasket set.
24601
24601
Thanks DT -- That's what I needed to know! Off to the garage!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
I have run into a mismatch of manifold and exhaust pipe types before where the manifold flange was flat to accept a flat gasket, while the exhaust pipe was made for a donut.
I didn't want to go through the hassle of changing out one or the other to fix the problem.
What I did find out was that someone makes a donut which is flat on one side and chamfered on the other and fixed the problem. I don't know who offers those. I believe that incidentally I acquired it at a swap meet in box of miscellaneous parts.
24601
24601
Everything matched up and the truck is quiet again!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
The manifold designed for the donut has a 45 degree chamfer on the inside diameter, and the exhaust pipe should have a corresponding flare at the end of the pipe. The companion flange that clamps the pipe to the manifold slides freely on the pipe and it does not touch the manifold. Exhaust pipes intended for earlier manifolds that use a flat gasket have the flange welded to the pipe, and it sandwiches the gasket tight between the manifold and the flange.
These double height brass nuts help the flange stay tight:
www.ebay.com/itm/134070873892?
Most auto parts stores stock them, so there's no need to mail order. The thread size is 3/8-16.
