Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
I want to hook up my vacuum gauge to tune my Carter BB1 updraft carb that's mounted on my 1962 235 motor in my Grumman-Olson Kurbside step van/Chevy P30
My intake manifold has a two port fitting screwed into it. The vacuum port circled in red goes to my windshield wipers. The vacuum port circled in green goes to the PCV valve.
I plan on removing the hose to the wipers and hooking up my vacuum gauge to that port. My question is, can I then do my carb adjustment, or do I need to block off the vacuum port going to the PCV valve to do the adjustment ?
Unless you plan to remove the PCV valve permantly, I'd leave it connected, temporarily remove the wiper hose and hook the vacuum gauge there
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
The PVC valve is essentially a consistent vacuum leak. This needs to hooked up when adjusting the carburetor whether you use a vacuum gauge or a tachometer. If you unkook the PVC, then adjust the carburetor, your settings will be off when you hook the PVC back up.
