Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Guitplayer, greenie-reddy, dt235sd, frogfarmer), 101 guests, and 2 robots.
Topics128,279
Posts1,058,593
Members48,492
#1614329 10/30/2026 4:12 PM
Attached are photos of camshaft lobes that show pitting. All lobes have the similar pitting. The camshaft bearing support look ok and could be resurfaced.
Asking if this camshaft is repairable?
You should be able to get it re-ground. If you do, get it ground to 261 specs.
BC
1960 C60 pasture art
Thanks you. But why to 261 specs? If so how does that impact the solid tappets ? Right now the tappets need to be resurfaced.
Same cam grind used on early Corvette 235 engine.
Uses same solid lifters.
BC
Contact Schneider cams in San Diego CA. They can put just about any grind on a good camshaft core, and they have experience with stovebolt camshafts. +1 on the 261 cam specifications, or use the specs for the Melling CCS-1 cam, which has a little more exhaust valve duration for better cylinder scavenging without causing a rough idle. Compared to a reground cam, I'd just go directly to the Melling cam without bothering to try to get an original cam reground.
