Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
Attached are photos of camshaft lobes that show pitting. All lobes have the similar pitting. The camshaft bearing support look ok and could be resurfaced. Asking if this camshaft is repairable?
Contact Schneider cams in San Diego CA. They can put just about any grind on a good camshaft core, and they have experience with stovebolt camshafts. +1 on the 261 cam specifications, or use the specs for the Melling CCS-1 cam, which has a little more exhaust valve duration for better cylinder scavenging without causing a rough idle. Compared to a reground cam, I'd just go directly to the Melling cam without bothering to try to get an original cam reground. Jerry
