Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Guitplayer, greenie-reddy, dt235sd, frogfarmer), 101 guests, and 2 robots.
Topics128,279
Posts1,058,593
Members48,492
I
I Offline
Hi folks,
I want to hook up my vacuum gauge to tune my Carter BB1 updraft carb that's mounted on my 1962 235 motor in my Grumman-Olson Kurbside step van/Chevy P30
My intake manifold has a two port fitting screwed into it. The vacuum port circled in red goes to my windshield wipers. The vacuum port circled in green goes to the PCV valve.
I plan on removing the hose to the wipers and hooking up my vacuum gauge to that port. My question is, can I then do my carb adjustment, or do I need to block off the vacuum port going to the PCV valve to do the adjustment ?
Thanks!
-Konstantine
~~ Konstantine
1962 Grumman Olson Kurbside/Chevy P30
Follow in the DITY
B Online: Content
Unless you plan to remove the PCV valve permantly, I'd leave it connected, temporarily remove the wiper hose and hook the vacuum gauge there
I
I Offline
Okay, thanks!
No, the PCV valve is remaining.
That's what I figured, but wanted to make sure.
~~ Konstantine
Follow in the DITY
The PVC valve is essentially a consistent vacuum leak. This needs to hooked up when adjusting the carburetor whether you use a vacuum gauge or a tachometer. If you unkook the PVC, then adjust the carburetor, your settings will be off when you hook the PVC back up.
I
I Offline
Thanks. That makes perfect sense. I kind of figured this would be the case but wanted to be certain. I appreciate your help.
~~ Konstantine
Follow in the DITY
