| | | Forums66 Topics128,233 Posts1,057,673 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2022 Posts: 32 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 32 | Has anyone replaced spring and frame using high density foam? I am going to build seat from hd foam and I am curious as to how thick/tall to make it.
53 chevy 3100
| | | | | Joined: May 2015 Posts: 11,215 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,215 | I have not done a foam seat for my Stovebolt, but on my F250, I've had the seat covers repaired and the foam on that is roughly 4" thick. That might give you a starting point. Get some 3" thick and 4" thick foam samples and test sit them on a piece of plywood. I would make the seats about the same height as the originals.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2007 Posts: 1,042 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,042 | I know little about seat foam, but when restoring my '37 the seat springs were too deteriorated to use. I only had the seat base frames. This truck has a split front seat. My upholstery guy suggested using high density foam, which ended up being 5 or 6 inches thick. Seven years later the seats look and feel great. So the seat construction is vinyl, foam and a plywood base attached to the seat frame. Kent | | | | | Joined: Jun 2022 Posts: 32 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 32 | my originals were a complete mess, about how thick were the original springs and padding?
53 chevy 3100
| | | | | Joined: Jun 2022 Posts: 32 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 32 | Just saw some dimensions in another thread that will help. Thanks.
53 chevy 3100
| | | | | Joined: Mar 2010 Posts: 10,315 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,315 | I am shocked that someone has not mass-produced all-foam seats for theses trucks. I have read about someone creating them for themselves. I don't remember who it was. They used a more dense rated foam and used progressively less dense foam on top of the dense layer. Three layers total if I remember right.
| | | | | Joined: May 2015 Posts: 11,215 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,215 | Good point Carl, Seat springs that are 70+ years old take a beating. There are enough of these trucks out there that there would be a market for them.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2019 Posts: 4,522 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,522 | Your link is asking for your approval for me to see your document.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Apr 2017 Posts: 91 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 91 | ops, flipped the access to anybody using the link… should work | | | | | Joined: Feb 2000 Posts: 5,245 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,245 | I have a few seat foams I robbed out of school bus seat from work. They are quite dense and about 4" thick. The foam is not a solid one piece, but lots of small crumbles molded into one slab, I believe it what makes it stiffer. Back cushion foams are single injected types of foam, softer and more pliable, and thinner. You will want a stiffer foam for the base and outer edges with a softer foam in the middle, so when you set it feels similar to a bucket seat. A one piece slab won't have much feel or control to it. The stiffer edges will help keep its shape longer. The bus drivers seat foam is an injected foam, after a few years, they are just flat foam, with no shape left. I would also want an open bottom to the plywood base with heavy webbing for a little give and air flow, similar to a lawn chair.
Go to your local foam dealer and stack up a few different grades and set on them, keep swapping grades till you find a combination you like. We just bought a new bed mattress, one of the latex types with three different firmness to choose from. I like a firm mattress, so one side has three layers of firm, the other side is one firm, one medium, one soft. It feels really good and you can really tell the difference in how you stack the slabs, we tried a few variations. Your seat base needs to be the same way, you just have to try a few to see how you are going to like them. Theres nothing worse then an uncomfortable seat on a long drive.
My '37 seat frame was decent but the outer edge springs were worn out. I had no support under my knees and leaned towards the door. I cut some of the bus seat foam in to small slabs and shoved up through and around the seat springs to stiffen the edges. It made a huge difference in how I felt on long drives. No more back aches or stiff knees, and when cornering, I don't feel like I'm going to fall out anymore. | | | | | Joined: Sep 2009 Posts: 6,077 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,077 | ops, flipped the access to anybody using the link… should work Kilted54 - Your link works fine now and that's a great write up with pictures. Thanks for sharing!
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Apr 2017 Posts: 91 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 91 | Added a few more pics including one that shows finished seat in the cab. Not a great pic as I am installing a fresh air heater and rewiring the truck, which means to much crap in the cab and I am to lazy to clean it out for a good picture.
For me, It is easier to edit, spell check and clarify using google docs then on message board. | | | | | Joined: Sep 2009 Posts: 6,077 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,077 | I saw in one of your pictures that you had some of the cotton batting present during your seat work. Did you end up using that in addition to the foam or not used??? If it was used, was it used as a "top layer" under the seat cover?
