2 members (BC59, dt235sd),
137
Mod | | | Forums66 Topics128,233 Posts1,057,579 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2022 Posts: 32 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 32 | Has anyone replaced spring and frame using high density foam? I am going to build seat from hd foam and I am curious as to how thick/tall to make it.
53 chevy 3100
| | | | | Joined: May 2015 Posts: 11,201 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,201 | I have not done a foam seat for my Stovebolt, but on my F250, I've had the seat covers repaired and the foam on that is roughly 4" thick. That might give you a starting point. Get some 3" thick and 4" thick foam samples and test sit them on a piece of plywood. I would make the seats about the same height as the originals.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2007 Posts: 1,042 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,042 | I know little about seat foam, but when restoring my '37 the seat springs were too deteriorated to use. I only had the seat base frames. This truck has a split front seat. My upholstery guy suggested using high density foam, which ended up being 5 or 6 inches thick. Seven years later the seats look and feel great. So the seat construction is vinyl, foam and a plywood base attached to the seat frame. Kent | | | | | Joined: Jun 2022 Posts: 32 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 32 | my originals were a complete mess, about how thick were the original springs and padding?
53 chevy 3100
| | | | | Joined: Jun 2022 Posts: 32 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 32 | Just saw some dimensions in another thread that will help. Thanks.
53 chevy 3100
| | | | | Joined: Mar 2010 Posts: 10,311 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,311 | I am shocked that someone has not mass-produced all-foam seats for theses trucks. I have read about someone creating them for themselves. I don't remember who it was. They used a more dense rated foam and used progressively less dense foam on top of the dense layer. Three layers total if I remember right.
| | | | | Joined: May 2015 Posts: 11,201 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,201 | Good point Carl, Seat springs that are 70+ years old take a beating. There are enough of these trucks out there that there would be a market for them.
