Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (pauld, DennisM, Chev4t6, lumbersawyer, Phak1, J Lucas), 110 guests, and 0 robots.
Topics128,279
Posts1,058,593
Members48,492
See other Threads on this engine’s Teardown.
Today while inspecting the oil manifold ports at the crankshaft supports I got a big surprise, that being that there is what looks like a sheared drill bit or something like that at the #1 front crankshaft oil port. I’ve blown compressed air e into the hole and I can feel air coming out at the oil pump manifold oil line adapter fitting.
All other oil ports fed from the manifold are clear and compressed are flows well.
I’ve thought that the local engine shop could drill the blocks hole, extract whatever it is, and install a flush bushing to make up for amount shaved off. OR just leave it alone, and cross my fingers.
See attached picture. The in question here is the top hole not the blind hole.
I’ve resolved the mystery of what’s in the #1 oil lubrication port.
I trying to extract the foreign object I accidentally pushed it deeper into the oil lubrication manifold. I had to remove the front oil manifold cap and then I was able to extract the FOD. It looks like someone during this engine overhaul plugged the port with aluminum foil.
See attached pictures
Possibly melted babbit from a burnt out bearing?
