0 members (), 91 guests, and 2 robots.
Topics128,223
Posts1,057,522
Members48,473
#1614047 10/26/2026 7:34 PM
I
I Offline
Has anyone replaced spring and frame using high density foam? I am going to build seat from hd foam and I am curious as to how thick/tall to make it.
53 chevy 3100
IHPWR #1614049 10/26/2026 7:47 PM
I have not done a foam seat for my Stovebolt, but on my F250, I've had the seat covers repaired and the foam on that is roughly 4" thick. That might give you a starting point. Get some 3" thick and 4" thick foam samples and test sit them on a piece of plywood. I would make the seats about the same height as the originals.
IHPWR #1614066 10/26/2026 9:48 PM
I know little about seat foam, but when restoring my '37 the seat springs were too deteriorated to use. I only had the seat base frames. This truck has a split front seat. My upholstery guy suggested using high density foam, which ended up being 5 or 6 inches thick. Seven years later the seats look and feel great. So the seat construction is vinyl, foam and a plywood base attached to the seat frame.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
IHPWR #1614083 10/27/2026 2:24 AM
I
I Offline
my originals were a complete mess, about how thick were the original springs and padding?
53 chevy 3100
IHPWR #1614098 10/27/2026 12:20 PM
I
I Offline
Just saw some dimensions in another thread that will help. Thanks.
53 chevy 3100
IHPWR #1614133 10/28/2026 1:02 AM
I am shocked that someone has not mass-produced all-foam seats for theses trucks.
I have read about someone creating them for themselves. I don't remember who it was.
They used a more dense rated foam and used progressively less dense foam on top of the dense layer. Three layers total if I remember right.
IHPWR #1614137 10/28/2026 2:36 AM
Good point Carl, Seat springs that are 70+ years old take a beating. There are enough of these trucks out there that there would be a market for them.
Moderated by  ndkid275, Phak1
