Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Ghost_Rider, texas46), 115 guests, and 1 robot.
Topics128,279
Posts1,058,593
Members48,492
I recently picked up this King spark plug tester type G-102. It appears to be in working order...pushing the black test button on the right side causes the needle to move. I do not know anything about using it. Can anyone shed some light on this piece of equipment? Is there any value to it? I grabbed it with the thought that someone here may actually be able to use it and put in back into service.
These types of tester will only show you that the plug can arc. Since the cylinder pressure in an engine is always changing, you can't be sure how a plug will act under driving conditions. I pulled six plugs out of a Cummin's 8.9L natural gas engine that misfiring on all six cylinders, it was bad enough the engine wouldn't hardly idle. I put all six on my distributor machine and hooked up the wires coming off a Delco points distributor. I could run the rpm all the way up to 6300 and all six plugs fired perfect. Due to the hybrid engines 14:1 compression, the plugs would not fire correctly in the cylinders, but would work in the open atmosphere. Same things happen in less compression, some plugs just won't fire. It's a neat tool, and the guys that used them years ago had plenty of experience with them, but probably could tell you it was bad just looking at the plug without using anything but their eyes and ears.
They were around when I started twisting wrenches almost 70 years. Even back then I had no use for them because plugs fail under compression. But it is an interesting conversation piece.
Moderated by  MNSmith
