Brrrr
place holder
0 members (), 75 guests, and 1 robot.
Topics128,274
Posts1,058,431
Members48,489
#1613571 10/19/2026 12:55 AM
Moderated
Moderated
Hello looking to do a build on a 1946 Chevy 2 ton truck just wondering if I could get some input im wanting to keep the original frame but I wanting to swap out the two piece wheels looking for recommendations on axle swaps or wheels spacers adapters i have seen replacement wheels thats are around $550 a rim so trying to avoid thats any help would be appreciated
Socket Breaker
Socket Breaker
Sweet truck, you should head over to the Big Bolts section. Look around in there. Good luck and welcome.
Welcome! Love that truck!
As mentioned, lots of good info over in the Big Bolts forum. You might be able to find 19.5" wheels with the same bolt pattern. They're a little smaller but still don't look too bad. My '59 truck has them. (See link in my signature line.)
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Crusty Old Sarge
Crusty Old Sarge
That's a solid looking truck, could be it had some partial restoration work done years ago from the look of the paint. Like Rich, I have changed over 19.5 wheels, the tire selection is somewhat shorter in height. As with axles, I would start by determining the width of your original. Later model Trucks may prove to be a lot wider. You should also consider your brakes as well when changing axles, your Truck no doubt has Huck style brakes, later Trucks would more often then not have Bendix. Do some homework first, it will save you a lot of grief later.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
