1 members (Alex52),
136
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 1,110 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,110 | I am upgrading my front brakes to disc on my 54. I also have a dual reservoir MC. I installed a 2 psi residual valve on the front brakes. Should the 2 psi pressure held on the line be enough to hold the calipers/pads tight against the rotors? I can rotate them but it takes some real effort.
| | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | You should check with the supplier to determine if the Master cylinder already has built in residual valves. Many do and you don't want to duplicate the effort. Fred
| | | | | Joined: Jan 2016 Posts: 1,110 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,110 | I confirmed the MC does not have a built in residual valve before adding it. | | | | | Joined: Feb 2004 Posts: 29,876 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,876 | What's the diameter of the caliper pistons? For instance, a 2.5" diameter piston with 2 PSI against it will create nearly 10 pounds of clamping pressure on the brake pads. That will definitely cause some drag, and possibly overheat the rotors. Does the drag on the rotors go away if you crack a bleeder screw open? Jerry
| | | | | Joined: Jul 2000 Posts: 2,204 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,204 | For disk front / drum rear setup, you need a combination valve. Some call it a "proportioning valve". Like this: Combination valve
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2016 Posts: 1,110 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,110 | I do have a proportioning valve and a 10 psi residual valve on the rear brake line. | | | | | Joined: Jan 2016 Posts: 1,110 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,110 | I do have 2.5" pistons. Is my best option to remove the residual valve? | | | | | Joined: Feb 2000 Posts: 5,237 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,237 | I've been running disk brakes ( '70 - '79 Camaro/Firebird ) since 2000 with out residual valves. I have a combination valve from a early '80 s Chevy car, and a adjustable proportioning valve on the rear brake lines. The rear adjustable is pretty much mandatory due to the lack of weight on the rear axle during braking.
I have never seen the need for the residual valves, why do you want the brakes to drag? The reason I always hear is, they keep the fluid in the line and not overfilling the master cylinder since it's frame mounted. So how does the fluid return, you ever try to push a caliper back in? Gravity in a little brake line nots going to do it. How did the truck stop for the first 50 years with the valves in the lines?
A simple test, go out and step on the brake pedal like you normally due to stop the truck, measure how far down it goes. do it a couple ties with 5 to 10 minutes between each test.
Remove the valves and bleed out the system.
Repeat the above test and see if the calipers are retracting farther. Wait and hour so the fluid has plenty of time to retract and measure the pedal distant again. | | | | | Joined: Jan 2016 Posts: 1,110 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,110 | One of the reasons I need a residual valve is the MC sits below the floor and I have to pump the breaks when I first get in the truck because the gravity drains the fluid back toward the MC. That said, I have figured out at least part of my issue with the tight calipers. I was thinking logically. The brake line outlet pointing toward the front of the vehicle would be the brake line for the front brakes. Wrong. I have my front and rear brakes lines reverse on the MC although I don't understand why that could be an issue. Stay tuned. Once I straighten that out I will see if I can get the system working correctly.
| | | | | Joined: Feb 2000 Posts: 5,237 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,237 | I still don't believe the fluid will pull the pistons back, the master would have to be way below the caliper and the lines would need to be much bigger. It's more likely the rear brakes are not adjusted up correctly. With a master cylinders on the firewall, just how much fluid pressure do you think there is pushing through a 3/16" steel line on a caliper seal? It barely bleeds out with the line open.
Originally, the drums all worked correctly, why would disk brakes be any different?
I'm just asking, not trying to offend anyone, I just keep hear the same things over and over on multiple web sites with out any proof its correct.
Bet if you actually measure the fluid hight in the master and front caliper, bet theres hardly any difference, more likely the master is above the caliper slightly. | | | | | Joined: Jun 2021 Posts: 107 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 107 | On the cars that I work on, the front brake line is attached to the port nearest the pedal plunger, which is the back port on a firewall mount. I installed my under floor ones the same way. The plunger points to the front of the truck, and I attach my front line to that front port.
1950 GMC 100 Panel Truck, 1958 270, 3-spd Saginaw with BW OD, 3.73 12 Bolt Differential from a 1966 C10, Front Disc Brakes Hill Holder Bought it in pieces 9-1976, driving since 6-1978 Follow in the DITY | | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | Originally, the drums all worked correctly, why would disk brakes be any different? Because, while wheel cylinders aren't typically designed this way(I can't think of any), some calipers are designed to roll the piston back in to the body. | | | | | Joined: Feb 2000 Posts: 5,237 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,237 | The caliper piston is suppose to be pulled back by the square cut seal, that's how they keep from dragging all the time. But to say gravity on the fluid is pulling them back even farther, that's the point I don't believe.
Hope he gets this straighten out where he can drive it, I plumbed mine backwards once, it did not stop right ! | | | | | Joined: Jan 2016 Posts: 1,110 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,110 | I am not saying gravity pulls the calibers back. I was saying with the old system everytime I got in the truck I had to pump the brakes. I was told that is because with the lines higher than the MC fluid would drain back into MC causing excessive pedal travel until I pumped them up. | | | | | Joined: Feb 2000 Posts: 5,237 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,237 | Then how does fluid run back without pulling the piston with it? The only way it can run back without pulling the piston is if air is entering the caliper past the seal, if this is the case, then the caliper is bad.
Measure the master cylinder fluid level from the garage floor, then measure up to the caliper at the base of the bleeder screw to see just how much difference in hight there is. | | | | | Joined: Jul 2000 Posts: 2,204 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,204 | ISTM that you still have air in the system. ("pumping them up" is a clue) With the MC under the floor, I found it really difficult to get all the air out. I had to bleed the system about 4 times before I got it right. The pedal would seem OK and I drove it for many miles without issue. Then the pedal went to the floor when backing out of a parking stall with the steering fully cranked over. Or the pedal would drop on an extremely steep driveway, just when you really need the brakes.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2016 Posts: 1,110 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,110 | As I stated earlier. I had the issue of needing to pump the brakes on my old set up. My question was related to the residual valve holding too much pressure against the rotor. I am still building out my new set up and have no idea how they will perform. | | | | | Joined: Jul 2000 Posts: 2,204 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,204 | We are just trying to help.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2016 Posts: 1,110 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,110 | I appreciate it. I just waned to clarify I am not having that issue with the disc brakes.
| | | | | Joined: Jan 2016 Posts: 1,110 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,110 | I found the problem. Very strange. It probably explains why I had to pump the brakes with my old system. New system. Dual MC, front disc conversion, 2 psi residual valve for disc and 10 psi residual valve for rear shoes. I completed bleeding the system and I pumped up the brakes and they felt good. I came back a minute later and had to pump them up again and verified the calibers were still holding tight. My brake pedal has always been about 2 inches higher than the clutch pedal. Just by chance, I realized when pumping the brake, if I only allowed the pedal to return to about the same height as the clutch pedal, the system held pressure. I installed a block under the floor that allowed to pedal to only return to the same height as the clutch pedal. This solved the problem of needing to pump the brakes up and the locking calipers. I am guessing, but I think the MC plunger was coming too far back internally allowing the rear line to drain back into the master cylinder and blocking the port for the front line causing it to hold pressure on the calibers. Google says this is not possible but can happen in reverse. The internal plunger staying too far forward. I have no real explanation but they work now. | | | | | Joined: Feb 2000 Posts: 5,237 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,237 | I agree with google, something is still wrong. The master cycling is designed to fully retract till it hits the snap ring retainer. At that point, you should have .060" or so clearance between the push rod and master cylinder. All cars, trucks, and everything else is set up this way.
By not letting yours return, you are blocking one of the return ports, very likely the rear half.
As a test, tighten the rear shoes up to the drums to the point the wheels are locked.
Remove your stop so the master can return to its internal stop, then try the pedal a couple of times to see if you need to pump it after it sets.
As it is now, you will likely drag the brakes and over heat them.
To adjust the floor height, trim the push rod to lower the pedal, then install a stop on the back side of the pedal so the return spring doesn't pull it to high, it still needs the required clearance (free travel).
You also MUST make sure the pedal does not hit the floor at any time, a full panic stop, two foot on the brake, should be solid without hitting the floor or carpet. | | |
