| | | Forums66 Topics128,167 Posts1,057,015 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 1,103 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,103 | I am upgrading my front brakes to disc on my 54. I also have a dual reservoir MC. I installed a 2 psi residual valve on the front brakes. Should the 2 psi pressure held on the line be enough to hold the calipers/pads tight against the rotors? I can rotate them but it takes some real effort.
| | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | You should check with the supplier to determine if the Master cylinder already has built in residual valves. Many do and you don't want to duplicate the effort. Fred
| | | | | Joined: Jan 2016 Posts: 1,103 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,103 | I confirmed the MC does not have a built in residual valve before adding it. | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | What's the diameter of the caliper pistons? For instance, a 2.5" diameter piston with 2 PSI against it will create nearly 10 pounds of clamping pressure on the brake pads. That will definitely cause some drag, and possibly overheat the rotors. Does the drag on the rotors go away if you crack a bleeder screw open? Jerry
| | | | | Joined: Jul 2000 Posts: 2,202 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,202 | For disk front / drum rear setup, you need a combination valve. Some call it a "proportioning valve". Like this: Combination valve
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | |
